Notices
Old 19th September 2006, 07:40 PM   (permalink)
Experienced Member
HiTech is a glorious beacon of lightHiTech is a glorious beacon of lightHiTech is a glorious beacon of lightHiTech is a glorious beacon of light
Hold on, we'll be right there!
HiTech is offline   Reply With Quote
Old 31st October 2006, 08:11 PM   (permalink)
krl
krl is on a distinguished road
how big shold the led's be?
v:
mA:
Type?
krl is offline   Reply With Quote
Old 30th June 2007, 07:20 PM   (permalink)
DAPortman is on a distinguished road
My opener uses 9 dip switches, but they are all single pole, triple throw (sptt). The throws are open (0), closed (+), and closed (-). I'm also having trouble locating info on the ic: +B8608 (top) MM53206N (bottom). I can't think of any way to adapt for sptt dips, any suggestions?
DAPortman is offline   Reply With Quote
Old 14th July 2007, 10:25 AM   (permalink)
bradindenver is on a distinguished road
I have been in the garage door industry for 13 years.
can anyone tell me how to mod the remote to send all the codes at one time.
The new rolling codes work with a set code and a set clock. That is how it is so hard to break. But I think if you over run the buffer with to many codes at one time it would open the door.
The only way for me to test this would be to build a remote that sends to many codes at one time.
I know an airplane transponder does this to an opener.
It is just a bet.
[[/i]
bradindenver is offline   Reply With Quote
Old 21st September 2007, 09:52 PM   (permalink)
Experienced Member
Helder Ferreira is on a distinguished road
Default All codes at once??
First of all, a garage door opener sends the code in a serial form, in a series of "on's" and "off's" of different timings, usually starting with a "on" pulse of a known duration to syncronize a receiver. When the receiver receives a correct sequence, repeated a certain amount of times, depends on the decoder, it signals the relay to open the door. An ancient chip the TEA5500, used in old Renault vehicles, working no in RF but Infrared, locked itself out for some time, after, I think, 5 wrong codes. You could still hide some device to "steal" the code and then use it to violate the lock. With roling codes, the story is a little different. The Keeloq technology from Microchip, uses a very complex algorithm to calculate a 69 bit long key, every time it transmits a code. Each new code shuffles at least, half off the bits. The code is generated using yhe algorithm, a serial number, unique to each device and a user progammed code. The receiver knows exacly the code he's going to receive when the key transmits, so if it receives a pre-used "stolen" code, it will lock itself out. If you play with the key, without being near the receiver, you also risk being lockek out as well, sinse the receiver will not recognize your key because it can only calculate the the "rolled" key a few keys away from the last one. By the way, every key for a certain lock, must be associated, so each key is unique. It's therefor impossible to send more than one code at a time.
PS. Pardon my English.
Greatings,
HF
Helder Ferreira is offline   Reply With Quote
Old 25th September 2007, 10:51 PM   (permalink)
Experienced Member
You do realize that this thread is from July 2005!!
Old 25th September 2007, 11:15 PM   (permalink)
Experienced Member
Yeap, I know. Just trying to answer the post from the 14th July 2007 about sending the codes all at once
Old 8th January 2008, 09:39 PM   (permalink)
cordcole is on a distinguished road
do any 1 now where to get the garage door open or any other circuit with out the garage door opener? shoud i use a microcontroller or should i spend $150.00 for a kit at http://www.plans-kits.com/kits.html?
cordcole is offline   Reply With Quote
Old 9th January 2008, 09:55 PM   (permalink)
Experienced Member
tytower is on a distinguished road
Interesting -are the rolling codes used in cars different? I have a car key and a spare .When I use the spare after 12 months or so it still opens the car -different gear?
I Hate Microsoft-the site below says it well
http://www.vanwensveen.nl/rants/micr...eMS_intro.html
tytower is offline   Reply With Quote
Old 11th January 2008, 09:29 PM   (permalink)
Experienced Member
The receiver calculates and waits for the next code for each key. If you store one key, there should be no problem exept, maybe (I'm not sure) if the battery runs down. You can read all about rolling codes at www.microchip.com . They call it KEELOQ
Old 28th June 2008, 02:22 PM   (permalink)
Experienced Member
shokjok will become famous soon enough
If you have a Sears Home Central depot where you live, you give them the model number and problem details ( or go online to Sears' website) to assist you in troubleshooting. If no manual is available, Sears can re-direct you to the manufacturer of the opener. I don't suggest playing around with this device, as household AC voltages can be nasty and unforgiving.
shokjok is offline   Reply With Quote
Block Garage Door Hacker Tom McCurdy General Electronics Chat 10 20th December 2004 05:06 AM
Garage door hacker schmatic cyberquest Electronic Projects Design/Ideas/Reviews 5 21st June 2004 01:24 PM
Parking Garage Project ---HELP dmiga Electronic Projects Design/Ideas/Reviews 2 30th May 2004 03:58 PM
Wiring 220V sub to garage Wounded General Electronics Chat 10 17th May 2004 02:14 AM
Garage Door Opener Fuzzygrowth Electronic Projects Design/Ideas/Reviews 13 11th September 2003 10:16 AM
