Notices
Old 6th March 2007, 04:41 AM   (permalink)
kazimahbub is on a distinguished road
thanks for share
kazimahbub is offline   Reply With Quote
Old 18th October 2007, 09:19 PM   (permalink)
Experienced Member
cannibal is on a distinguished road
Hello
I didn't understand the part of contacts
how it will be and how it will work if the water touchs it ??!!!
cannibal is offline   Reply With Quote
Old 19th October 2007, 12:43 AM   (permalink)
Experienced Member
audioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to behold
Water has some salts in it then it is conductive.
When water is between the contacts in the first circuit then it turns on the transistor that turns on the oscillator.
Old 22nd October 2007, 06:51 AM   (permalink)
abu emran is on a distinguished road
Thanks For All
abu emran is offline   Reply With Quote
Old 27th December 2007, 05:48 PM   (permalink)
xl5
xl5 will become famous soon enough
Can i insert a photocell in this cct to prevent it triggering when rain falls during the night when i am in bed and if so where in the cct should it be best placed without effecting the operation too much.
xl5 is offline   Reply With Quote
Old 27th December 2007, 06:30 PM   (permalink)
mudassir_semiconductor is on a distinguished road
i made a automatic dam door control system using 555 timer but after that ...... i tought 0f using microcontroller and i did it ..... insted of all this u can only do by switch which will activate on any conduction ....... r ugetting me ..... this circuit is only for the understanding of transisters
mudassir_semiconductor is offline   Reply With Quote
Old 27th December 2007, 06:31 PM   (permalink)
Experienced Member
I added an LDR (light dependent resistor) and a 100k resistor. When it is light then the LDR is a low resistance and the 555 operates normally. When it is dark then the LDR is a high resistance and the 100k resistor causes the 555 to be reset. Try different values for the 100k resistor.
This way, the battery is drained about 5ma when the sensor is wet in the dark. If the sensor is not wet then there is no drain.
Old 29th December 2007, 05:46 PM   (permalink)
xl5
Default Rain alarm.
Hi Audioguru, thanks for posting the cct diagram with ldr i will now try the cct out on my breadboard. My very first project was a rain alarm back in 1972 it worked fine but if it was not switched off before retiring for the night sometimes it doubled as an extremely early alarm clock
I have in the junk box many types of ldr's i will experiment with the resistor value.
Old 9th January 2008, 02:34 PM   (permalink)
umairtheonlyone is on a distinguished road
Hey can anyone tell me about the speaker part I couldnot find it in the parts list in ewb
umairtheonlyone is offline   Reply With Quote
Old 9th January 2008, 03:06 PM   (permalink)
Experienced Member
The 555 has a max allowed output current of 200mA so it might be damaged if it directly drove an 8 ohm speaker when it has a 9V supply. Use an 18 ohm speaker or connect a 10 ohm resistor in series with an 8 ohm speaker.
Old 10th January 2008, 06:44 PM   (permalink)
I cannot find the speaker anywhere I mean LS1 is not in my parts list in electronic work bench
Old 10th January 2008, 06:47 PM   (permalink)
I cannot find LS1 anywhere in electronics work bench parts list
Old 17th January 2008, 04:15 PM   (permalink)
Rachel49 is on a distinguished road
can i change BC109C to BC107?? plz help me...
Rachel49 is offline   Reply With Quote
Old 17th January 2008, 04:18 PM   (permalink)
Super Moderator
You could try, but a BC109 is a much higher gain device - so it depends how conductive the water is.
Old 21st January 2008, 04:15 AM   (permalink)
RAKS will become famous soon enough
Thanks for all.
Blatent advertising deleted! - moderator.
RAKS is offline   Reply With Quote
Need Low Volume Water Pump Noggin General Electronics Chat 27 26th June 2007 04:32 AM
submerging a pressure sensor under water? AndyWatson Electronic Projects Design/Ideas/Reviews 14 26th October 2006 09:37 AM
water activated alarm godwin Electronic Projects Design/Ideas/Reviews 2 3rd May 2004 07:26 PM
alarm activated by heat Emma.Deary Electronic Projects Design/Ideas/Reviews 1 30th October 2003 12:57 AM
water activated electronic switch help eightwgt Electronic Projects Design/Ideas/Reviews 4 30th June 2003 08:46 AM
