Notices
Old 25th July 2002, 01:18 AM   (permalink)
Administrator
ElectroMaster has disabled reputation
Default Modular Burglar Alarm
This circuit features automatic Exit and Entry delays and a timed Bell Cut-off. It has provision for both normally-closed and normally-open contacts, and a 24-hour Personal Attack/Tamper zone. It is connected permanently to the 12-volt supply and its operation is "enabled" by opening SW1. By using the expansion modules, you can add as many zones as you require; some or all of which may be the inertia (shock) sensor type. All the green LEDs should be lighting before you open SW1. You then have up to about a minute to leave the building. As you do so, the Buzzer will sound. It should stop sounding when you shut the door behind you. This indicates that the Exit/Entry loop has been successfully restored within the time allowed. When you re-enter the building you have up to about a minute to move SW1 to the off position. If SW1 is not switched off in time, the relay will energise and sound the main bell. It will ring for up to about 40 minutes. But it can be turned off at any time by SW1. The "Instant" zone has no Entry Delay. If you don't want to use N/O switches, leave out R8, C8 and Q2; and fit a link between Led 3 and C7. The 24 Hour PA/Tamper protection is provided by the SCR/Thyristor. If any of the switches in the N/C loop is opened, R11 will trigger the SCR and the bell will ring. In this case the bell has no time limit. Once the loop is closed again, the SCR may be reset by pressing SW2 and temporarily interrupting the current flow. The basic circuit will be satisfactory in many situations. However, it's much easier to find a fault when the alarm is divided into zones and the control panel can remember which zone has caused the activation. The expansion modules are designed to do this. Although they will work with the existing instant zone, they are intended to replace it. When a zone is activated, its red LED will light and remain lit until the reset button is pressed. All the modules can share a single reset button. The Stripboard layout of the prototype is available.
Electro Tech Online Owner
Need to contact me? Send me a Private Message.
Verification Email didn't arrive? See this thread.
ElectroMaster is online now   Reply With Quote
Old 7th December 2005, 05:32 AM   (permalink)
Experienced Member
rancid rock is on a distinguished road
Send a message via AIM to rancid rock Send a message via MSN to rancid rock Send a message via Yahoo to rancid rock
i think my jaw just hit the floor, how much would something like this cost to make?, parts etc.
<( \"<)....kirby!!!....0==[=====>
rancid rock is offline   Reply With Quote
Old 8th March 2006, 07:39 AM   (permalink)
Experienced Member
how is the alarm activated and de-activated???
Old 17th March 2006, 07:38 PM   (permalink)
Experienced Member
philba is just really nicephilba is just really nicephilba is just really nice
interesting project - probably not that costly to build. I bet the relay costs the lion's share.
One the NC contacts - I would design them to have a 10K resistor in parallel at the sensor and set off the alarm or refuse to arm if you don't see the resistance. A simple divider allows that. this prevents some one from cutting or shorting the wire. same for the NO contacts.
philba is offline   Reply With Quote
Old 27th January 2007, 04:20 PM   (permalink)
Experienced Member
Sig239 is on a distinguished road
Here is a link to the rest of the support material for this modular alarm system including:
1 Circuit Description
2 Power Supply
3 Parts List
4 Veroboard Layout
5 Construction Guide
6 External Connections
7........
http://uk.geocities.com/ronj_1217/mba_support.html
I hope this helps anyone intent on building this.
Sig239 is offline   Reply With Quote
Old 15th September 2007, 07:52 AM   (permalink)
Experienced Member
AND_ECE is infamous around these parts
sir can you build a burglar alarm consisting a transitor
AND
AND_ECE is offline   Reply With Quote
Old 15th September 2007, 10:27 AM   (permalink)
Experienced Member
wot iz tranziztor?
i dont undorstond.
Last edited by Hero999; 15th September 2007 at 10:27 AM. Reason: Wow, we do have some retards on this forum!
Old 15th September 2007, 02:23 PM   (permalink)
Experienced Member
blueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to behold
Send a message via Skype™ to blueroomelectronics
Originally Posted by Hero999
wot iz tranziztor?
i dont undorstond.
Perhaps this link will explain.
http://icanhascheezburger.com/
Bill
Smart Kits build Smart People
Old 15th September 2007, 07:48 PM   (permalink)
Moderator
Krumlink is a glorious beacon of lightKrumlink is a glorious beacon of lightKrumlink is a glorious beacon of lightKrumlink is a glorious beacon of lightKrumlink is a glorious beacon of light
Send a message via Skype™ to Krumlink
Lol, this made my day a bit better.
Krumlink is offline   Reply With Quote
Old 16th September 2007, 09:10 PM   (permalink)
Experienced Member
This question was also quite funny.
http://www.electro-tech-online.com/e...p-request.html
Burglar Alarm System Circuit johno Electronic Projects Design/Ideas/Reviews 7 20th March 2006 01:27 AM
Need help with burglar alarm for a model house. rancid rock Electronic Projects Design/Ideas/Reviews 27 15th March 2006 06:55 AM
burglar alarm chriz Electronic Projects Design/Ideas/Reviews 1 21st June 2005 09:16 PM
burglar alarm chriz Electronic Projects Design/Ideas/Reviews 1 21st June 2005 05:44 AM
Burglar alarm help. compute_a_nerd Electronic Projects Design/Ideas/Reviews 8 8th February 2005 07:50 PM
