Notices
Old 9th January 2007, 12:52 PM   #16 (permalink)
Experienced Member
HiTech is a glorious beacon of lightHiTech is a glorious beacon of lightHiTech is a glorious beacon of lightHiTech is a glorious beacon of light
I have a 3 horsepower 110vDC motor from a treadmill machine. That will likely require some very stout components to operate it!
HiTech is offline   Reply With Quote
Old 30th January 2007, 09:04 AM   #17 (permalink)
bhusoy is on a distinguished road
Send a message via Skype™ to bhusoy
thanks for your advices...
Let's fly from here...
bhusoy is offline   Reply With Quote
Old 15th February 2007, 03:10 PM   #18 (permalink)
Banned
cadstarsucks will become famous soon enough
Send a message via Yahoo to cadstarsucks
That is exactly what they are for. Normal consumer grade stuff uses 1-2HP. The PWMs that drive it use 50A IGBTs, though the continuous current is limited to 15-25A depending on the unit.
D.
cadstarsucks is offline   Reply With Quote
Old 15th February 2007, 03:15 PM   #19 (permalink)
Banned
Originally Posted by ElectroMaster
Here, S1 and S2 are normally open , push to close, press button switches. The diodes can be red or green and are there only to indicate direction. You may need to alter the TIP31 transistors depending on the motor being used. Remember, running under load draws more current. This circuit was built to operate a small motor used for opening and closing a pair of curtains. As an advantage over automatic closing and opening systems, you have control of how much, or how little light to let into a room. The four diodes surriunding the motor, are back EMF diodes. They are chosen to suit the motor. For a 12V motor drawing 1amp under load, I use 1N4001 diodes.
You should just put the two LEDs anti parallel, as it stands you are breaking the unlit one down. They typically have a 5V reverse breakdown rating.
And you need to change the 1N4001s to schottkys. 1N4001s are slow diodes that are not worth anything far beyond line frequency.
D.
Old 28th July 2007, 09:06 AM   #20 (permalink)
Experienced Member
AND_ECE is infamous around these parts
hey its really nice to be a member...
can you help to build an driver of the step motor (8 coils), to control the direction of torque if the motor
AND_ECE is offline   Reply With Quote
Old 6th October 2007, 10:16 PM   #21 (permalink)
h.d
Experienced Member
h.d can only hope to improve
D.
hi am have a project to design treadmill
and i hope to know how i can do the PWM controlling by the PIC microcontoller? and if i can use the same circuit which added in ur replay
h.d is offline   Reply With Quote
Old 15th October 2007, 05:30 PM   #22 (permalink)
Experienced Member
anthony123 is on a distinguished road
Send a message via MSN to anthony123
that circuit is well know here in Latinoamerica... but we prefer use a PWM with el dual timer 556..
anthony123 is offline   Reply With Quote
Old 24th January 2008, 08:26 PM   #23 (permalink)
pbency is on a distinguished road
Default PWM circuit
Can anyone give me the PWM circuit of CD motor control with all the component value. I was looking for the snubber circuit and the MOSFET used.
Regards,
Bency
pbency is offline   Reply With Quote
Old 21st February 2008, 08:27 AM   #24 (permalink)
stevenlaw188 is on a distinguished road
Did anyone know how i can use thyristor (SCR) as power switch to drive a 12VDC Motor and LDR to control the direction?? Please help me for my project. Thanks.
stevenlaw188 is offline   Reply With Quote
Old 2nd May 2008, 10:27 AM   #25 (permalink)
Experienced Member
Ubergeek63 can only hope to improve
You can't, there is no way to conveniently turn it off.
Ubergeek63 is offline   Reply With Quote
Old 2nd May 2008, 10:56 AM   #26 (permalink)
Experienced Member
Gayan Soyza is just really niceGayan Soyza is just really niceGayan Soyza is just really nice
If you visit the Robotics Section in this site there are about 100 topics regarding line followers/ light followers.
They are using this input sensors ex:LDR & IR in their robots.Also have plenty posts regarding how to control a speed of a motor.
Gayan
Forum Supporter
Gayan Soyza is offline   Reply With Quote
Motor control circuit crunch53 Electronic Projects Design/Ideas/Reviews 3 12th November 2005 04:02 PM
Need a timing circuit for motor control crunch53 Electronic Projects Design/Ideas/Reviews 2 16th October 2005 01:39 PM
Looking for AC motor speed control circuit Tako Kichi Electronic Projects Design/Ideas/Reviews 3 4th August 2004 06:17 AM
control circuit to motor circuit does it matter what wire i? troyandash Robotics Chat 2 21st May 2004 11:26 AM
4 stepper motor control circuit- help!!! ajay_kumar_d Electronic Projects Design/Ideas/Reviews 3 19th March 2004 11:54 AM
ElectronicKits.com
