| Electronic Projects A collection of small electronic circuits and projects you can build. |
This IC chip was designed specifically for use in power boosting applications in automobiles. It is self protecting against short circuits and thermal problems.In the bridge configuration shown it will deliver 20 watts of power into a 2 ohm speaker operating at 14.4 volts.
__________________ ▌ Electro Tech Online Owner ▌ Need to contact me? Send me a Private Message. ▌ Verification Email didn't arrive? See this thread. | |
is there a way to step up the output, i would like to get it to around 250 watts
No way. Build a larger more complicated circuit for the 250W. | |
hey dude could u tell me about making an amplifier for my car subwoofer. .im in urgent need for this.
For a sub you'll need a lot of power and it'll almost certainly be cheaper to buy a ready made one.
__________________ Angry!? I'm absolutely electrolytic! Music web page: http://www.music-playground.net/artist/drem/ | |
| | #6 |
i believe these triangular shapes r the operational amplifiers,correct me if i m wrong.
| | #7 | |
| | #8 | |
you cant get any more power on that IC its characteristic is the same as LM2005T 20 watts bridge connection for a 250 watts, you can only attain this power by using higher supply voltage such as +/-35 volts
__________________ power sources can kill so always use safety precautions when dealing with it | ||
| | #9 | |
__________________ Don't make me reach through this monitor to slap you a good one! | ||
| | #10 |
hi i think i can make this 20 watts to give around 100 - 200 watts output... if your interester mail me: game_master_287@yahoo.com k... | |
| | #11 |
can I use this circuit for 5 watt RMS Power audio Amplifier with low distortion.....if yes plz reply the require changes.....it's urgent for me.... plz urgently | |
| | #12 | |
If you want very low distortion then use a hi-fi amp IC. They need a supply voltage much higher than a car battery and drive 8 ohm speakers.
| | #13 |
thanks buddy ....for this suggestion...i have made the correct ckt diagram....
| | #14 |
ooooooooooooooooooooo....
| | #15 |
Baaaaaaaaaaaaaaaaaaaaaaaaaaaaaa......
| Need help For Thesis About An 8 Watt Audio Amplifier | Jajazz | Electronic Projects Design/Ideas/Reviews | 2 | 6th July 2004 12:07 PM |
| 20 watt Amplifier Project | hotwaterwizard | Feedback/Comments | 0 | 9th June 2004 02:00 AM |
| Need Help w/ 100 watt linear audio amplifier | mmahmud1 | Electronic Projects Design/Ideas/Reviews | 2 | 29th May 2004 06:17 PM |
| 50 Watt Amp Power Supply Critique | Johnson777717 | Electronic Projects Design/Ideas/Reviews | 5 | 5th March 2004 10:45 PM |
| Dual-input 1 Watt Amplifier | hollyd | Electronic Projects Design/Ideas/Reviews | 0 | 27th July 2003 01:01 AM |
