| Electronic Projects A collection of small electronic circuits and projects you can build. |
| | #16 |
hello guys i need a 200 watt audio amplifier for my major project, i need a stable and working ckt which looks a big project plz try to help me | |
| | #17 |
Well copying someone elses work probably isn't going to get you much of a mark?. But try here! http://www.ampslab.com/projects.htm | |
| | #18 |
Here is the list of ic's. little old but ok. Now new development r class D based & not suitable for newbies. | |
| | #19 |
How far would I need to drive to buy old low power Russian amplifier ICs?? About 20,000km?
| | #20 |
Is there anyone interest with creating new Hi-End Audio Amplifier thread? I've initiate it, but I've no access to do it. I'll help to start it with my 7th version K32 that been fixed in dec2005. And also analyze old halcro schematic. | |
| | #21 |
There are lots of good audio amplifier schematics on the web.
| | #22 |
But not here. Nor the halcro's. Just want to offer. | |
| | #23 |
How about this historical article: http://www.edexcel.org.uk/VirtualCon...list_units.pdf "High Performance Audio Power Amplifiers for Music Performance and. Reproduction (Butterworth-Heinemann, 1997)". It contains much great invention and schematic, also devices. | |
| | #24 |
tda2005 or lm2005 is not really effetive 20 watts power output... it is usually used for a booster amplification in car audio....
| | #25 |
is there any other better power amp that can be used for a radio? what is the suitable power range that can be used for a radio?
| | #26 | |
Unless you are worried that a speaker that is strong enough for high power is too big and heavy for a little radio. You can make an amplifier with thousands of watts of power. Then you can use a powerful speaker like this very powerful Jackhammer:
| | #27 |
In the schematic, pins 1 and 2 are reversed. It won't sound good if assembled according to this diagram. It cross-references to an NTE1396 ( 11-pin SIP).
| | #28 |
| a simple audio amplifier that can deliver 45 watts of power if supplied with a dc more than 12 volts say at least 14.4 volts
__________________ power sources can kill so always use safety precautions when dealing with it | |
| | #29 |
Car radio amplifiers are bridged and deliver about 18W per channel to a 4 ohm speaker at clipping with a 14.4V supply. Even the ones that advertise 200 Whats. Philips have some car radio amp ICs with a voltage doubler for nearly 4 times more power.
| | #30 |
| Really simple! No part numbers or component types. Maybe 45 watts square wave into 2 ohms. Do you enjoy square waves? They are a bit harsh for my taste.
| Need help For Thesis About An 8 Watt Audio Amplifier | Jajazz | Electronic Projects Design/Ideas/Reviews | 2 | 6th July 2004 12:07 PM |
| 20 watt Amplifier Project | hotwaterwizard | Feedback/Comments | 0 | 9th June 2004 02:00 AM |
| Need Help w/ 100 watt linear audio amplifier | mmahmud1 | Electronic Projects Design/Ideas/Reviews | 2 | 29th May 2004 06:17 PM |
| 50 Watt Amp Power Supply Critique | Johnson777717 | Electronic Projects Design/Ideas/Reviews | 5 | 5th March 2004 10:45 PM |
| Dual-input 1 Watt Amplifier | hollyd | Electronic Projects Design/Ideas/Reviews | 0 | 27th July 2003 01:01 AM |
