| | #61 |
As I presumed, you haven't cut the unused tracks on the board, so you have lot's of extra capacitance sending the frequency way off - assuming it will even oscillate like that.
| | #62 | |
The white strips on the component side is just a paint pattern of the copper strips on the other side.
| | #63 |
i have already cut those that is connecting. And i have already confirm with a multimeter that its not linked.
| | #64 | |
![]() I didn't realize that was white. As you guessed, I thought I was looking at tin or solder plating. | ||
| | #65 |
| You need to cut, or (and) remove all unused strips as well.
| | #66 |
Only for digital circuits and audio frequency usually I was use such this PCB, for high frequency only PCB or I was made or buy. RF circuits are not good on experimental PCB The experimental PCB not good for such this, and make own PCB is really cheap and easy and more fun. Frequency are measure using Frequencies meter. Anny will be work good. | |
| | #67 |
Yuanong, it looks like you are missing a capacitor (should be 3 on the transistor oscillator), and I don't see the emitter resistor.
| | #68 |
this image shows my component value compare to audioguru circuit. Did i miss any component? If yes please tell me. Thank you ![]() http://www.electro-tech-online.com/a...tter-again.png | |
| | #69 |
Where's R1?
| | #70 |
R1 is block by the LED | |
| | #71 |
| Yuanong, did you do this?
| | #72 |
yup, i have already done. its small now.
| | #73 |
You must slowly tune the transmitter with a plastic bladed screwdriver because a metal screwdriver blade will mess up the capacitance. It does not transmit a tone, it transmits silence. You will hear the FM background noise in an FM radio go quiet each time the LED lights. The radio must not have muting.
| | #74 |
You are doing a wonderful job. The first piece of test equipment you need is a "power meter." It simply detects if you have RF present. ![]() Once you know you have RF. you can work on getting the frequency somewhere on the 88-108MHz band. | |
| | #75 |
Here is a Tracking Transmitter that uses easy-to-obtain components: | |
| Attempting to make a Keyfob transmitter... | adamthole | Electronic Projects Design/Ideas/Reviews | 7 | 25th November 2006 01:05 PM |
| usb soundcard with fm transmitter | Gideonstk | Electronic Projects Design/Ideas/Reviews | 2 | 14th June 2006 02:31 PM |
| Viability of tracking device | Glyph | Chit-Chat | 3 | 25th August 2005 07:33 PM |
| Transmitter | zachtheterrible | General Electronics Chat | 3 | 5th August 2004 10:56 AM |
| Using LEDs to show the direction of a tracking transmitter | Electric Rain | Electronic Projects Design/Ideas/Reviews | 1 | 18th June 2004 12:09 PM |
