Old 13th March 2009, 11:43 PM   #46
Now i get what is enamel insulation.
The coil wire i am using are already enamel insulation.
I bought those copper cable from a shop that make transformers and motor.
Thanks for the infomation=D
yuanong is offline
Old 14th March 2009, 12:08 AM   #47
yuanong - wrap it around a pencil and put nail polish on it to hold it together.
duffy is offline
Old 14th March 2009, 12:23 AM   #48
I used wire that is 1mm in diameter so it is very strong and does not need anything to hold it together.
audioguru is offline
Old 14th March 2009, 12:29 AM   #49
WTF? If you do that you won't have an excuse to buy nail polish! Get with the program.
duffy is offline
Old 14th March 2009, 02:19 AM   #50
Originally Posted by yuanong View Post
i have already tried to solder one myself.
as in the image
But i can't get the frequency of a Fm radio frequency range.
Can someone help me and point out the mistake that i have made?
all the components i got are the same from the circuit diagram.
Thanks a lot.
This doesn't look like Veroboard. Is it?
Ron
Roff is offline
Old 14th March 2009, 02:34 AM   #51
The picture is too blurry to see what is there.
Old 14th March 2009, 06:27 AM   #52
Thanks for the advice. I need it.
It is a veroboard.
Sorry for the blurry 1st image. Did't got a chance to get a new handphone yet.
yuanong is offline
Old 14th March 2009, 03:19 PM   #53
i can't open a new theard does anyone here mind me posting another type of circuit to ask about it?
yuanong is offline
Old 14th March 2009, 07:13 PM   #54
Tell the head kiwi you can't start a thread.
duffy is offline
Old 14th March 2009, 10:38 PM   #55
Anyway going out 88-108 MHz range not good idea, first if simple oscillator run over 108 MHz this is violation of law(in USA violation FCC rules)
108-135 MHz are airplane frequency , 121.5 MHz are homing distress frequency.
So if somebody live near airport and make a "trip out frequency" unexpected visit from governments are nothing new. Be sure that oscillator not running too long time.(If you not sure exact frequency)
1oskar is offline
Old 16th March 2009, 12:46 PM   #56
hi, i have follow all of the steps that is mention above but the frequency i got from an oscilloscope indicating the frequency is not stable.
Is it the frequency i get from the oscilopscope is incorrect or
Is there anyway to make the frequency stable or have i done any mistake that make the frequency not stable?
yuanong is offline
Old 16th March 2009, 01:40 PM   #57
You can't measure it with a scope, and your layout (although far too blurred to see much detail) looks unlikely to work.
Nigel Goodwin is online now
Old 16th March 2009, 03:56 PM   #58
May i know what can measure the frequency that it produce?
here is a image that i have redo.
Can please pin point out the mistake that i have made?
is the coil still to far apart?
yuanong is offline
Old 16th March 2009, 04:10 PM   #59
The instructions say to make the coil "close wound". The turns on your coil are much too far apart which causes the frequency to be too high. The wire for the coil is supposed to be insulated with enamel so that when the close turns are touching then they do not short together.
My FM transmitter has "close wound" turns.
AG, I don't understand how you build your boards. This one has no solder showing, no cut tracks, and apparently bare jumpers across tracks. How does that work? What's on the back side?
Ron
Roff is offline
Old 16th March 2009, 04:27 PM   #60
this is whats under it. And sorry my soldering skills is reali bad
those burn parts is at 1st i can solder in the coil.
After i scarpe of the enamel then it only can
but those burn parts i did't use those places
or should i just redo the whole thing over?
yuanong is offline
Attempting to make a Keyfob transmitter... adamthole Electronic Projects Design/Ideas/Reviews 7 25th November 2006 01:05 PM
usb soundcard with fm transmitter Gideonstk Electronic Projects Design/Ideas/Reviews 2 14th June 2006 02:31 PM
Viability of tracking device Glyph Chit-Chat 3 25th August 2005 07:33 PM
Transmitter zachtheterrible General Electronics Chat 3 5th August 2004 10:56 AM
Using LEDs to show the direction of a tracking transmitter Electric Rain Electronic Projects Design/Ideas/Reviews 1 18th June 2004 12:09 PM
