| | #31 |
ic....sori did't notice it ther does any mind telling me wats a emitter resistor? if i m asking wrong question sori cuz i m reali noob here... Last edited by yuanong; 15th January 2009 at 02:35 PM. | |
| | #32 |
| Look at hundreds of FM transmitter circuits in Google. They all have an emitter resistor like this:
| | #33 |
I keep getting PMs from this guy. No it won't work if it is made on a breadboard. It will work if it is made compactly on a pcb or on Veroboard. I made mine with Veroboard and the circuit is small. Here is a pic that shows a mess of a circuit that does not work because its parts are spread out all over the place, and my circuit that is compact even though it has many more parts.
| | #34 |
I do not need 30 miles , but for dog tracking up to 1 mile.(Using time difference of arriving signal, or pseudo Doppler) Do not worry I have amateur radio license and law say I can use frequency exactly determined by lay, power and modulation. So I need something with almost practically zero drift , exact frequency (out side amateur frequency I violate law) small battery consumption, low voltage. Very old transmitter used for wild animal tracking, look like good, but semiconductors 40 year before and today are not same. ![]() (original blue print are just a little change according today electronic components) Anybody have fresh idea? Thank you. P.S. Today for wild animals nobody use such simple device. P.S.S. Now professional device use satellite ,GPS , not simple homing principle. But I do not need GPS and other for me expensive device. | |
| | #35 |
hi, hop you dun mind me asking noob question... if you got coil d y do you need crystal sumore? i dun quite get how the circuit works? | |
| | #36 | |
A crystal gives a very accurate frequency. It also has a coil and capacitor tuned circuit. A coil and capacitor tuned circuit allows the frequency to be changed if something moves toward or moves away from the antenna because then the tuning capacitance is changed by stray capacitance. I think the crystal oscillator will stop if something moves toward or moves away from the antenna.
__________________ Uncle $crooge Last edited by audioguru; 10th March 2009 at 06:51 PM. | ||
| | #37 |
Coil and capacitor (I am not invented this, schematic diagram is from professional device early 1960 ) need because oscillator work on 3 time higher frequency than crystal frequency. I do not know how type crystal (quality)was used in original wild animal tracking device 40-45 year before. But now it is easy found newer used computers crystal, petty cheap. Exactly Uncle Scrooge, it possible some change frequency on output if you multiple few time basic crystal frequencies. (I was long ago use on amateur frequency transmitter with 18 multiply,from 8MHz to 144MHz and easy drift 25 kHz + - ) Problem stopping oscillation, good idea Uncle Scrooge, this simple oscillator not simple like look maybe, it work on rf frequency, but also on-off to save battery(Low oscillation too). So I try found something secure in work. | |
| | #38 |
high power trnsmiter
| | #39 |
i have already tried to solder one myself. as in the image ![]() But i can't get the frequency of a Fm radio frequency range. Can someone help me and point out the mistake that i have made? all the components i got are the same from the circuit diagram. Thanks a lot. | |
| | #40 | |
You need to build HF oscillators on a board with ground plane on one side, short leads on all components, and good power supply decoupling. Last edited by Roff; 13th March 2009 at 06:48 PM. | ||
| | #41 |
The instructions say to make the coil "close wound". The turns on your coil are much too far apart which causes the frequency to be too high. The wire for the coil is supposed to be insulated with enamel so that when the close turns are touching then they do not short together. My FM transmitter has "close wound" turns.
| | #42 | |
That means if the coil is further apart will get higher frequency? My coil is not over frequency but not enought frequency, is it cause of there is no insulation? erm, I am sorry do you mind explaining more or do you have a link that i can refer to about HF oscillators? I am new to electronics. Thanks | ||
| | #43 | |
I have also used single-sided copperclad board and drilled holes and cut pads with a pad cutter (I can't believe they cost US $64 ).You can also use the dead bug method (scroll down).You can also use Veroboard for small circuits that don't need a ground plane. Last edited by Roff; 13th March 2009 at 10:32 PM. | ||
| | #44 | |
I just don't know how to insulate the coil with enamel. | ||
| | #45 |
I used wire that is made with an enamel insulating coating. I got it from a speaker's crossover coil. A transformer also has enamel insulated wire. The frequency of your transmitter is too high because the turns on the coil are too far apart. The turns are supposed to be tight together and the wire is supposed to have enamel insulation. My FM transmitter is made on Veroboard that is also called stripboard because it has parallel copper strips.
| Attempting to make a Keyfob transmitter... | adamthole | Electronic Projects Design/Ideas/Reviews | 7 | 25th November 2006 01:05 PM |
| usb soundcard with fm transmitter | Gideonstk | Electronic Projects Design/Ideas/Reviews | 2 | 14th June 2006 02:31 PM |
| Viability of tracking device | Glyph | Chit-Chat | 3 | 25th August 2005 07:33 PM |
| Transmitter | zachtheterrible | General Electronics Chat | 3 | 5th August 2004 10:56 AM |
| Using LEDs to show the direction of a tracking transmitter | Electric Rain | Electronic Projects Design/Ideas/Reviews | 1 | 18th June 2004 12:09 PM |
