| | #136 | |
| | #137 |
would not be the same idea if you use C2 a coupling capacitor before the base of the transistor, that way you certainly will block any DC from coming in.
| | #138 |
| C1 blocks DC from the microphone. As Audioguru said, C2 kills the gain of Q1 at high frequencies, to prevent the RF output signal from screwing up the mic preamp.
| | #139 | |
Thanks for the reply, I got this. why there is no coupling capacitor before C2, and what does that LM IC doing to your transmitter with the capacitors in parallel? Last edited by andrebc; 24th April 2009 at 09:24 AM. | ||
| | #140 |
| C2 reduces the gain of the preamp transistor at radio frequencies. C1 is the coupling capacitor that couples the signal from the mic to the preamp transistor. What does that LM IC doing to your transmitter with the capacitors in parallel?[/quote] The LM2931A-5.0 is a low dropout 5V voltage regulator. Unlike an ordinary 7805 5V regulator that has a minimum input voltage of 7V, the LM2931 has a minimum input voltage of only 5.2V so the 9V battery will power it for a long time as it runs down. The 1000pF capacitors are for RF bypassing and the 100uF capacitors are for audio bypassing. The LM2931 must have a 100uF capacitor on its output for stability. The regulator keeps the oscillator from changing frequency as the battery voltage runs down and also keeps the preamp transistor biased correctly.
| | #141 |
smart idea using the IC, but why did not you use a coupling capacitor before Q2?
| | #142 |
| He does, what do you think C3 is?.
| | #143 |
| After reading Andrebc's posts, one wonders if he is looking at the same schematic we are. | |
| | #144 |
| Chill out Mr smart! dont get bothered by other members questions, just ignore them if you cant respond.
| | #145 | |
| | #146 |
| C12 is an RF coupling capacitor, and NOT an audio one.
| | #147 | |
C12 is 30pF and passes radio frequencies from 88MHz to 108MHz. The reactance of C12 at 100MHz is only 53 ohms so it passes the radio frequency very well. Q2 is the radio frequency oscillator and its output to C12 is near 100MHz.
__________________ Uncle $crooge Last edited by audioguru; 25th April 2009 at 02:43 PM. | ||
| | #148 |
Spam alert
| | #149 | |
| Attempting to make a Keyfob transmitter... | adamthole | Electronic Projects Design/Ideas/Reviews | 7 | 25th November 2006 01:05 PM |
| usb soundcard with fm transmitter | Gideonstk | Electronic Projects Design/Ideas/Reviews | 2 | 14th June 2006 02:31 PM |
| Viability of tracking device | Glyph | Chit-Chat | 3 | 25th August 2005 07:33 PM |
| Transmitter | zachtheterrible | General Electronics Chat | 3 | 5th August 2004 10:56 AM |
| Using LEDs to show the direction of a tracking transmitter | Electric Rain | Electronic Projects Design/Ideas/Reviews | 1 | 18th June 2004 12:09 PM |
