| | #16 | |
Keeping in mind the 5v PIC pins, an NPN/PNP pair or N-FET/P-FET pair for the high side drivers does indeed work well with traditional multiplexed displays but it's a bit problematic for Charlieplexed displays. Regards, Mike, K8LH | ||
| | #17 | |
Using wierd crystal frequencies always baffled me but if you can show me how to accomplish any operation in exact 1 usec increments using one of those crystal frequencies then you'll have a convert (grin)... | ||
| | #18 |
I can see how a 19.6608MHz crystal is good for serial communications but how is it any better for a real time clock? ![]() Mike. Last edited by Pommie; 10th September 2008 at 08:58 AM. | |
| | #19 |
| I can't see how it's any better for serial either, it works 100% perfectly with a 20MHz or 4MHz crystal - so how does getting an exact frequency match give any improvement?.
| | #20 |
| Ahhh. I see that now. In that case, you need another set of column transistors and invert the logic on the n-1 line? (I'm not really familiar with Charlieplexing, but I think I get it). MPU output drives base of NPN which pulls down the base of the PNP with it's emitter connected to 12 volts. Right?
| | #21 |
| Check the 'Hardware Extras' section of my tutorials for an example.
| | #22 |
| | #23 |
The "software trimmer" routine is described briefly in the 3rd or 4th post in this thread... Cap values for crystal | |
| | #24 |
| What on earth is this all about. Everyone is free to program in the language of his or her choice.
__________________ Please post questions to the forums. PM's are for personal communication. BCHS/3v0's Tutorials Junebug USB PIC programmer kit., USB Bit Whacker, The 15 Minute Printed Circuit Board! (+drill time) | |
| | #25 | |
![]() edit: Another thing is even on the 8253 TIC which is used in PC's their software correction occurs every few seconds to minutes. This one has all seconds the exact same length of time. Last edited by Space Varmint; 17th September 2008 at 05:15 AM. | ||
| | #26 |
SV, I am a C guy. I can read and write a little ASM but it help if there are lots of good comments and I have the cheat sheet nearby. IMHO we invented compilers for a very good reason... but as I said to each his own. But for the above reason I am not in any position to get in the middle of a debate about asm code. EDIT: I know I sort of stuck my big nose in this one.
__________________ Please post questions to the forums. PM's are for personal communication. BCHS/3v0's Tutorials Junebug USB PIC programmer kit., USB Bit Whacker, The 15 Minute Printed Circuit Board! (+drill time) Last edited by 3v0; 17th September 2008 at 03:56 AM. | |
| | #27 | |
| | #28 | |
I did not realise that you had written the code and I called it horrible because it is not even source code, it is a disassembly listing. This makes it very difficult to understand or use and practically impossible to alter. It also uses timer 0 which is a very bad timer to use for any sort of RTC. It writes values to the timer0 counter which always zeroes the prescaller. This combined with the variable latency of the interrupt will cause timing errors. As for not liking assembler, I wrote my first assembler program around 1980 and have been writing in it every since. Mike. | ||
| | #29 | |
Any latencies will be the same length of time as long as they are done the same way (TMR0). I know this without a doubt because I have used the same technique to produce a reference frequency for a PLL. I had a receiver tuned to the output frequency of the PLL with the BFO turned on so that I had a beat note (tone/pitch). If that were true what you said then I would hear a change in the pitch. The receiver was also digitally locked. I could purposely change the frequency by changing the "jam load" value and to demonstrate just how redundant the timing is with TMR0 I was able to use the timer to run through a do nothing loop and by changing an instruction I could change frequency just do to the different machine cycle times for different instructions. Summary: Latencies are repetitive not random. | ||
| | #30 | |
Please get your facts straight. I am the Original Poster (OP) and I didn't make any comments about your example program, good or bad. I also use a "software trimmer" of sorts in some of my Clock projects but did not include it in this novelty single-chip design. Thank you for pointing out the feature and for the program example. Mike | ||
| chip, clock, k8lh, novelty, single |
| Single Chip BCD Clock | Mike, K8LH | Micro Controllers | 4 | 3rd November 2008 05:00 AM |
| Drive 2 displays with a single 4511 chip? | ghall426 | Electronic Projects Design/Ideas/Reviews | 1 | 18th December 2006 09:45 PM |
| Program a single modem chip without AT-Cmd? | liupengjian | Micro Controllers | 0 | 26th July 2004 09:48 AM |
| About a suitable Single Chip CCD | girishns | Datasheet/Parts Requests | 1 | 29th January 2004 03:42 PM |
| Single chip H-bridge | Exo | Datasheet/Parts Requests | 4 | 24th November 2003 10:41 PM |
