| | #16 |
Electrode: A solid electric conductor through which an electric current enters or leaves an electrolytic cell or other medium. A collector or emitter of electric charge or of electric-charge carriers, as in a semiconducting device.
__________________ Freedom isn\'t Free. | |
| | #17 |
plz, tell me taht how I can know that someone tells me lie, means which is the indicator in the circuit.
__________________ hello to everyone , its swapnil here, i love electronics. | |
| | #18 |
M1 is the indicator
| | #19 |
The 2N3565 NPN Transistor is not available in my place.Can i use a substitution for that.Someone please reply as to where i can get that transistor.I live in india in a place called Mangalore.I liked the idea of this project and decided to do it.But now the transistor and the analog meter in unavailable.So pls tell me where can i get these two parts.
| | #20 | |
| | #21 |
What about the analog meter.Is there any substitution for that.Please post your replies at the earliest.Because i need to do this for my project.
| | #22 |
hi, ]i want to say that ur project is simply amazing.I would like to do this project and in this regard i'd need ur help about electrodes... can they be simple wires if so, if we connect those wires to the hands of the subject..is there any shock to the subject?? if it does what r the precaution to avoid shock. plz rpl early so that i can do the project thanks u once again...
__________________ N.praveen | |
| | #23 | |
| | #24 |
there is 0-1mA analog panel meter for $10.95 part #01MAO-1 at http://www.elexp.com/tst_mamo.htm, where were they for $5.?? this is a GSR meter, very neat thing.. the electrodes are usually attached to the index and middle finger, i have been looking for the velco ones with the wires attached and a plug..they can be made out of stainless steal washers, if it is possable to solder a copper wire in them..Hmmm i dont recall if you can solder stainless.?? and wrap velcro around them snugly on your fingers. i have an elestac wrist strap with quater size crome domed buttons, but i dont reall like it. i have a program for the PC where you move an image like a ballon across a picture and land it on a target by changing specific Brainwave levels to move it horozontally and vertically without thinking about it. If anyone is familure with Scientology, and i am NOT recomending them or their practaces to anyone, they have a special magoc meter where they have you hold to cylendars and they "Condition" with it ..it is a GSR meter. I used GSR in Behavior Modification Classes, Alcohol Addiction and Anger Management. the comercial units have a (+) or (-) pezio sound option where it buzzes when your hit your target level or stops buzzing, set with a moveable red line. i need to locate plans for a meter that reads the electrical impulses of the muscles, to make a meter that indicates when you are unconsciously vocalizing when you are reading.. you can increase your Words pr Minute by a factor of 500% to over 800% by hearing the beep when you think of the word and unconsciously vocalize it.. it is a very useful tool when teaching children to read. i forget what it is called. | |
| | #25 |
electrodes are electrical conductors, which are a metal or plated with a metal that doesnt corode or tarnish from the salt in the skin/although you couls polish something with some wet and dry sand paper each time. you might try soldering the lead wires on a plated tack and bending over the pin part after pushing it thru the velcro then bending it over to hold it in place. thevelcro is a piece about 1.5X longer than it takes to wrap around a finger/fury side up with a 1/2 in piece of the hoop side glued or sewn on top of one end to lock it down. try it on index and middle finger the GSR meter measures how much electricity is conducted between the electrodes, in this case it is actually how much sweat is present which contains salt, more sweat=more salt which is a conductor of the electricity flowing form one of the conductors/electrodes to the other, that is why there is battery in the unit, it supplies the current which is read by the meter. this is a really fun thing at parties.. you ask an embarising question for which the embarising answer will result in a higher reading.. proving it true. when one gets emotional the sweat glands release salt increasng the flow of electricity between the electrodes. the trick is to keep them calm till you put the question to them. | |
| | #26 | |
I posted this variation of the lie detector here. Quote:
| | #27 |
It should also be noted that In doing this kind of testing, The person should ask a number of easy questions, getting Correct answers and resulting in "No needle movement". Such as: What is the persons name? What is your age? Also get the person to purposely lie on a few sample questions. This somewhat helps Eliminate False readings from the person Just being Scared. This circuit has been around for many years. I think at least 30 years in a "popular electronics magazine" or simular type magazine. And Meters with Greater Sensitivity than 0 to 1 mA can be used, resuling in Greater variation on lies. Such as a 100 uA Meter.
__________________ I No Longer accept Private Messages on here. All Emails to me Must Contain the Word \"Electronic\" in the \"Subject Line\" or they go Directly to my Junk Mail Folder. Email me at: chemelec@hotmail.com Website: http://www3.telus.net/chemelec | |
| | #28 |
Thank you very much i needed that for my small deploma project
| | #29 |
also changing transistor to PNP and reversing polarity of C1, M1 and battery will convert it to truth detector :wink:
| | #30 | |
When you tell the truth, sweat (moisture and salt) gets sucked back into your sweat glands. I'm told that, if you are ever caught in a thunderstorm, you should recite every truth you know. This will increase your skin resistance and make you immune to lightning. Unless it's raining. | ||
| detector, lie, simple |
| A simple ultrasonic range detector????? | steven_first_2001 | Electronic Projects Design/Ideas/Reviews | 12 | 19th March 2009 06:08 PM |
| How to build a simple IR emitter & detector circuit | fun_feng | Electronic Projects Design/Ideas/Reviews | 4 | 15th March 2009 05:10 AM |
| Simple light detector | Macwarrior | Electronic Projects Design/Ideas/Reviews | 3 | 10th January 2005 11:55 PM |
| simple lie detector.................. | raj_11 | Micro Controllers | 1 | 11th October 2004 02:54 PM |
| Help wid the simple lie detector | umer007 | Electronic Projects Design/Ideas/Reviews | 4 | 14th February 2004 01:20 AM |
