Old 23rd February 2009, 12:53 AM   #136
The circuit is an extremely simple ohm-meter.
audioguru is online now
Old 25th February 2009, 03:34 AM   #137
So, If I'm a really sweaty gross kind of person. I'm a really bad lair.
I think someone really has it out for stinky sweaty people.
kv
Truthiness Monkeys : Obedience, Ignorance, Fear.
killivolt is offline
Old 25th February 2009, 04:08 AM   #138
kv
If you're a short circuit before the questioning starts, that's the baseline. You can lie like a rug and no one can tell.
Ron
Roff is online now
Old 25th February 2009, 04:46 AM   #139
This is based on the fact that when people lie they presumably sweat a bit because they are stressed. So many co-factors could explain the jumping of the multimeter, e.g. the lights in the room are too hot making the hand sweet or that theyr scared your going to shock them with your scary looking lie detector
Build this if your bored
Mike
birdman0_o is offline
Old 25th February 2009, 02:18 PM   #140
No, you build it for stinky sweaty people.
The when they lie during the interview you shock them for wasting your time.
kv
Old 24th March 2009, 07:03 AM   #141
sir,
why don't i get the selected thing.i am a student of 15years .give me simple low cost electronic project.
arun babu is offline
Old 9th April 2009, 11:56 PM   #142
You can get ECG electrodes from a hospital that stick on your skin to create a more-reliable connection. You can then measure the internal resistance of your body.
Most of the resistance of your body is in the small distance between the outside of your skin and the inside of the skin.
If you press harder on an electrode, the resistance decreases enormously.
This effect is much larger than the change in resistance due to sweating.
That's why lie detectors are so inaccurate.
I have a circuit for a "super-sensitive" lie detector for those with dry skin.
A person with dry skin does not activate a simple lie detector AT ALL.
colin55 is offline
Old 10th April 2009, 12:03 AM   #143
Actually lie detectors are inaccurate because a knowledgeable tester can manipulate the subject and a knowledgeable subject can manipulate the test. Last time I checked lie detector tests were inadmissible as evidence in US court because the test is so easily manipulated.
straight answer, har har."
Sceadwian is offline
Old 10th April 2009, 12:26 AM   #144
And even at best the interpretation of test results are very subjective.
I recall some decades ago the show 60 mins did a report/expose on lie detectors and the agencies that contract out their services. It was a setup where they pretended to be a small company that was having some office thefts and that while they suspected a specific employee who they did identify to the testers, they had no proof so wished to have all the office employees tested. The results from three different agencies were all the same and that was that the suspected employee was lying and only he was lying. Of course the suspected employee was an actor (as were all the 'employees') and was told not to lie. Funny that results equaled expectations! Of course all three agencies denied subjectivity (or worst, fraud) and said the tests were flawed because all the actors were not under real life stress. Also turns out that the lie detector association is a very profitable organization that 'sells' certifications for their 'member' agencies and help keep out independent and 'non licenced' and 'unqualified' testers.
As practiced, at least in that N.Y. city area, it is or was at least then a scam and just a way for some people to make a rather sleazy living.
Lefty
Measurement changes behavior
Leftyretro is offline
Old 10th April 2009, 06:43 AM   #145
Hopefully the trend is nearly spent =) I remembered from my 5 in 1 sheet from work.
Employee Polygraph Protection Act
Old 10th April 2009, 08:15 AM   #146
Interesting read. Did you notice all the exemptions from this law, nearly all government and military are not restricted in anyway from using polygraph testing.
Always strange how a goverment for and by the people can often pass laws that apply to normal people but exempt themselves.
Lefty
Old 1st May 2009, 04:14 PM   #147
And for the person looking for the M1 mA reader to make the schematic in pPsice... Just draw a short circuit and put your current probes on that node and have it output that to a graph. I'd take a digital multi meter and measure your skin, and use that as a load across where the electrodes would go. Then graph that current. Then you could increase and decrease the load resistance a little be and see how this effects the current. i.e. you would be modeling it after how a person's skin resistance could increase or decrease and the effect it would have on the current that you are motoring.
Zach is offline
Old 1st May 2009, 04:14 PM   #148
Hey guys I have a question was hoping could be answered. I'm an EE undergraduate student so I have been exposed to many type of transistor circuits.
Can you tell me what role the capacitor plays in this circuit? I do not understand why there needs to be a capacitor connected in between the two electrodes.
Zach is offline
Old 1st May 2009, 05:25 PM   #149
The cap is probably not necessary. Human bodies will generally have a lot of common-mode mains-related voltage (primarily 50 or 60Hz, depending on where you live), but this is relative to earth ground. I don't think there will be enough differential-mode noise to drive the transistor into saturation on the peaks, which would screw up the bridge. The cap is probably cheap insurance though, just in case.
Ron
Roff is online now
Old 15th May 2009, 12:20 PM   #150
can any one explain how it will work?
parthibank72 is offline
detector, lie, simple
A simple ultrasonic range detector????? steven_first_2001 Electronic Projects Design/Ideas/Reviews 12 19th March 2009 06:08 PM
How to build a simple IR emitter & detector circuit fun_feng Electronic Projects Design/Ideas/Reviews 4 15th March 2009 05:10 AM
Simple light detector Macwarrior Electronic Projects Design/Ideas/Reviews 3 10th January 2005 11:55 PM
simple lie detector.................. raj_11 Micro Controllers 1 11th October 2004 02:54 PM
Help wid the simple lie detector umer007 Electronic Projects Design/Ideas/Reviews 4 14th February 2004 01:20 AM
