Old 30th November 2006, 09:18 PM   #91
There must be a lot of friction in a rifle. Has one been made with its barrel and the bullets covered with teflon? Then you could shoot bullets into orbit and they would go through nearly anything.
audioguru is online now
Old 30th November 2006, 09:30 PM   #92
Lots of studies have been done regarding bullet coatings and barrel treatments. Either they are way to expensive for the avg. gun owner, don't last for long under the heat of firing, or diminish barrel life. Molybdenum is the best choice for bullet coatings but once a new barrel has seen it, the shooter should continue using it since on a molecular scale, the particles fuse to the barrel steel. There's alot more science to it than what I present here. There are dry lubricants applied to bullets as well. Barrel fouling is the most prevalent concern and that could affect shot accuracy. Here's a little snip about various bullet types as well as the special procedures for cleaning barrels that fire moly-coated bullets. So the diea of highly reduced friction between barrel and slug is not as desirable as you would think. I remember reading about some theory where if an astronaut were to fire a pistol downward on the moon, he'd sail into orbit.... that is if he doesn't shoot off his foot first, puncturing his pressurized suit!!
http://www.bergerbullets.com/tech-info.htm
If you were to take a proper sized slug and push it into a rifled barrel, you'd be amazed at what force is needed to manually push it through against the rifling (lands). Between the specific amount of friction necessary to rotate a bullet so it can maintain long range flight accuracy along with hot gases from the charge, barrels become hot very quickly and avg. quality ones will change the POI (point of impact). Good match grade barrels reduce these effects. Military grade barrels can withstand tens of thousands of shots before they wear out. Very high-grade sniper barrels have short lifespans in trade for extreme accuracy where only a few shots would be fired at a time... if that. Remember their motto: "one shot, one kill".
HiTech is offline
Old 4th December 2006, 08:49 AM   #93
Talking
How'z this for a stun gun, f'ckin blam!
2.4Gigglehurtz
chiba is offline
Old 5th December 2006, 02:04 PM   #94
WTH is he shooting? We have flame throwers that emit larger flames than that thing.
HiTech is offline
Old 6th December 2006, 09:16 AM   #95
It's a Blunderbuss
2.4Gigglehurtz
chiba is offline
Old 7th December 2006, 04:05 PM   #96
Originally Posted by ElectroMaster
This stun gun is powered by a 9V battery. The transformer steps up the voltage to about 1800V (but with very low current). A 555 timer IC is used to generate a high-frequency output. A 1 MEG variable resistor can also be used at the output to drop the voltage, but this is optional. If you build this circuit, be careful, as it outputs a high voltage. Touching the output leads will induce a painful shock.
NOTE: Building stun guns can be very dangerous! Please use caution.
given transformer is outdated.giv alternative.
vaibhav007 is offline
Old 7th December 2006, 07:23 PM   #97
Most little mains transformers will work. I recommend a 6V to 240V mains transformer.
if I know the answer.
Hero999 is offline
Old 16th December 2006, 07:12 PM   #98
Hey guys have built the circuit and i only get a shock on the output when i release the switch, i.e. i assume when the capacitors discharge but am not sure. Any ideas why this is doing this or is this right? I thought the shock should pulse, if it doesnt any easy ideas on how to make it pulse? cheers
leglesslizard is offline
Old 16th December 2006, 07:43 PM   #99
Isn't a legless lizard a snake? Welcome to our forum.
The 555 is supposed to oscillate. Yours doesn't.
Old 17th December 2006, 12:17 AM   #100
yeah nearly, you wouldnt know the difference by looking, but be warned it is there.
ok cheers any ways to resolve this? the 555 has been changed and im not sure why the circuit is not working really. how could i make it oscillate?
Old 17th December 2006, 12:24 AM   #101
If your diodes are backwards then the circuit will have your problem.
Old 17th December 2006, 07:33 AM   #102
they are round the right way, any more ideas? im not great with electronics and so am pretty stumped.
Old 17th December 2006, 02:14 PM   #103
Maybe your battery isn't strong enough. Its TIP31 power transistor conducts a lot of current from a brand new 9V alkaline battery that might last a few minutes. Get a new battery.
Old 17th December 2006, 04:07 PM   #104
Perhaps yout 555 isn't working, try another one.
Have you measure the battery voltage using a multimeter?
Hero999 is offline
Old 17th December 2006, 04:41 PM   #105
ive now got two batteries in series, dunno if thats wise the shocks bigger but is still only when you release the switch. So its still not oscillating. And yeah ive changed the 555 twice now still no luck. I am rebuilding it with slightly different bits, will let ya know if that one works. Still any ideas for why this one isnt working are appreciated
STUN GUN tripler Electronic Projects Design/Ideas/Reviews 60 13th November 2009 05:47 PM
stun gun farnoosh General Electronics Chat 0 1st June 2004 07:55 AM
stun gun farnoosh General Electronics Chat 0 1st June 2004 07:54 AM
stun gun help dstich Electronic Projects Design/Ideas/Reviews 0 21st May 2004 06:10 PM
Stun gun Arkan Electronic Projects Design/Ideas/Reviews 3 1st March 2004 01:20 PM
