| | #31 |
The thing is that i cant get my hands on any old transistor radio. also whats the difference between a Driver and a Output? | |
| | #32 | |
| | #33 |
hello, I too don't have that specific transformer for this project. But, I do have a small 220:1 transformer from a camera flash. Could I use this? I could use a 6v battery instead of 9V and get 1320V. Would it still work and is it safe to just shock a friend. Not to painful, and if they have a pacemaker, it won't kill them right :lol: . (OK...Thats not funny). Also, this taser doesn't do any permanet damage right? thanks, George L. | |
| | #34 | |
Incidently, in the UK such devices are seriously illegal, and it's a criminal offence to own one!. | ||
| | #35 |
Hello, I am giving this circuit a try. I am going to be VERY careful because it is dangerous. I started by breadboarding the 555 circuit without the transistor or the transformer. I already have a problem! I measure the AC output of pin 3 and only get .4 V I don't think this is right. I am using a .47uF electrolythic and a .01uF ceramic for the caps. Everthing is the correct value. Am I supposed to get .4V there and very little curent? thanks, George L. | |
| | #36 |
A little 555 IC can't drive a reverse-connected transformer all by itself. The power transistor was supposed to drive the transformer. So I guess you have fried your 555.
| | #37 |
Audioguru, I guess I wasn't clear on this, The transformer and transistor is not in my breadboarded circuit, I am just connecting pin 3 (without the resistor) to the multimeter and the other side to ground. The 555 is currently no driving anything. George L. | |
| | #38 | |
| | #39 |
I also noticed that the frequency is much higher than the mains frequency that a multimeter would measure accurately. The duty-cycle is a very low 1:47 as determined by the circuit's R1 and R3. A multimeter would measure a very low signal with such a low duty-cycle.
| | #40 |
That exactly it audioguru! I just changed the resistors to 12.2K (10K + 2.2K) and 100 ohms. I added a 1uF cap at the output. The multimeter now measures 2.5V AC at the output (ALMOST dead battey, 6.5V). I tried getting a current reading at the output, its not supposed to read anything right? I am pretty sure this is normal. I put a diode at output and it read 200mA+. That is BAD. If the AC with diode is 200ma+, does that mean the AC is also 200mA+? thanks for the help audioguru George L. | |
| | #41 |
You shouldn't connect a diode to ground at the output of a 555. It would be almost like a dead short and might destroy both the 555 and the diode if the power supply can provide the unlimited amount of current.
| | #42 |
YES! I got the circuit working on my breadboard. It was very fustrating because my meter was reading arond 300V at the transformer output when I am using a fresh 9V. The transformer is from a camera flash. Turns 1.5V into 330V. (220:1) I am using 9V and olny getting 300V out. I burned out 3 2N3904's so I just switched to a 2N3055. I have a diode at the output so I can read the DC on my meter. With the 2n3055 it reads OL, 500V+. The current was 7mA at the output. I touched the output with my pointer finger and thumb. WOW!!!! :shock: pain!!!! (I guess I did something right) My question is should I be shocking my self with AC or DC??? Also, there is no permant damage done to my hand (500+V at 7mA) is there??? It only tingled for a minute. No marks on my hand, and full function. What is a good current for a taser that woun't hurt that much? (Obviosly less than 7mA.) would really appreciate some help. thanks George L. (will post pics when finished) | |
| | #43 |
You can take may mA trough your figers it wil just hurt a lot.Its very dengeris if you get the curent trough your hart.The curently may knock it out if its rithem resulting in death. This is one hadn it the pocket rule. If you done it whith bouth hands it will go up your arm trough your whole body and down the otehr arm.Doing this is dengerus!!! I once was stupid enigh to discharge an 1uF cap wiled to 2kW in to my hand.It realy hurt and my figer was all red and hirt as hell.I never even dared to toch it whithout puting an screwdriver over it first.
| | #44 |
Removed due to excess of PMs about it
__________________ Angry!? I'm absolutely electrolytic! Music web page: http://www.music-playground.net/artist/drem/ Last edited by Dr.EM; 23rd September 2006 at 04:15 PM. | |
| | #45 |
That multiplyer has quite a lot of stages. After all those stages you prpboblby have very litle curent
| STUN GUN | tripler | Electronic Projects Design/Ideas/Reviews | 60 | 13th November 2009 05:47 PM |
| stun gun | farnoosh | General Electronics Chat | 0 | 1st June 2004 07:55 AM |
| stun gun | farnoosh | General Electronics Chat | 0 | 1st June 2004 07:54 AM |
| stun gun help | dstich | Electronic Projects Design/Ideas/Reviews | 0 | 21st May 2004 06:10 PM |
| Stun gun | Arkan | Electronic Projects Design/Ideas/Reviews | 3 | 1st March 2004 01:20 PM |
