Old 15th July 2009, 01:44 AM   #331
Default help?
can i get some help here ?
i made my gun and the picture here is 2nd Transformer
after my first step up transformer im getting ~170 V (pulsing DC @20khz) from 9V
primary of the first has ~20 turns, secondary has about 500
but after i connect that to the second transformer i get NOTHING out, and the voltage on the secondary of the 1st transformer drops to 0
what's up with that ?
tom3000 is offline
Old 15th July 2009, 02:03 AM   #332
Only 15 turns of wire is like a dead short to your 170V generator.
A little 9V battery has a low output current. When its voltage is stepped up by the first transformer then the 170V current is much less.
audioguru is online now
Old 15th July 2009, 03:25 AM   #333
i dont need high current, i just want to turn that 170 Volts into over 2000V...so what do i do to fix that ?
tom3000 is offline
Old 15th July 2009, 03:33 AM   #334
Besides the Turns, What is your total Schematic?
Yes the 15 turn Primary is a Bit Small, But reguardless of that.
To make this to work, you need to rectify T1's Output and use a suitable capacitor to store the 170 volts and build up current.
Also you need a suitable Pulse circuit to deliver the 170 volts in that capacitor to send pulses to T2.
Possibly about 2 or 3 pulses per Second.
You might check out the Schematics on my website. I use an SCR Pulse circuit.
I No Longer accept Private Messages on here.
All Emails to me Must Contain the Word \"Electronic\" in the \"Subject Line\"
or they go Directly to my Junk Mail Folder.
Email me at: chemelec@hotmail.com
Website: http://www3.telus.net/chemelec
chemelec is offline
Old 15th July 2009, 09:50 PM   #335
after screwing around with this for the entire month of june, i kinda figured that too, that i might have to use pulsing on the second transformer as well
the first transformer is pulsed at around 20khz, so you're saying that the pulsing of the 2nd one should be lower or higher ?
btw - both transformers i use have ferrid cores
tom3000 is offline
Old 15th July 2009, 11:17 PM   #336
Your First Transformer is OK at the 20khz. It doesn't really Matter, But you need to Rectify its output to DC and Filter it with a "Capacitor of about .1uF to .22uF".
That DC need to PULSE MUCH LOWER in Frequency.
Stun Guns do Not produce a Steady High frequency output. Actually Slow Pulses.
In your case, Only about 2 to 5 HZ.
The Exact speed will be Determined by How Fast your Capacitor can "RECHARGE".
And that will partly depend on your First Oscillator Circuit, as well as your Batteries Capability. Nicad and Nimh are good, or a Lithium battery is even better.
(Cheap Batteries will Not deliver enough current.)
Gary
chemelec is offline
Old 3rd September 2009, 11:31 AM   #337
show me some procedure. i want to build the said circuit
greatwolf is offline
Old 4th September 2009, 08:50 PM   #338
Sorry, I'm on a Holiday in Niagara Falls right now.
chemelec is offline
STUN GUN tripler Electronic Projects Design/Ideas/Reviews 60 13th November 2009 05:47 PM
stun gun farnoosh General Electronics Chat 0 1st June 2004 07:55 AM
stun gun farnoosh General Electronics Chat 0 1st June 2004 07:54 AM
stun gun help dstich Electronic Projects Design/Ideas/Reviews 0 21st May 2004 06:10 PM
Stun gun Arkan Electronic Projects Design/Ideas/Reviews 3 1st March 2004 01:20 PM
