Old 15th March 2008, 01:24 AM   #256
So, you're saying that I don't really need a transformer to increase the voltage? Just a 30kv cap, then make it so that it charges up and then release the charge.
zultekmilennia is offline
Old 15th March 2008, 02:41 AM   #257
Ha, no.
He said a 30kV cap charger. If you thought that you could charge a 30kV cap to make it 30kV, try something easier. No really, you could easily hurt/kill yourself.
IF YOU WANT TO HELP FINE IF NOT PLEASE DON"T PEE IN MY CHEERO'S
Krumlink is offline
Old 15th March 2008, 03:49 AM   #258
No, You still need an Oscillator and transformer circuit to Get the 30 or 60KV. But instead of a Continuous Output you only want to "momentarly" charger the capacitor to give the shock.
But considering your understanding, I would recommend you don't attempt this.
I No Longer accept Private Messages on here.
All Emails to me Must Contain the Word \"Electronic\" in the \"Subject Line\"
or they go Directly to my Junk Mail Folder.
Email me at: chemelec@hotmail.com
Website: http://www3.telus.net/chemelec
chemelec is offline
Old 15th March 2008, 10:19 AM   #259
Yeah, I really don't want that much power. I suck at EC, but thought I could pull off at least this one.
Anyways, I still need to build it, so I'll go for a continuous output, but I still need to know what kind of change I need to make for the parts. I got a cellphone charger (Nokia) which has a input of 240v ac and output of 5v-11v. Can I use it?
or I need to pluck the transformer out and use that instead?
Old 16th March 2008, 10:38 AM   #260
Originally Posted by jrigg
do you use a breadboard to build this circuit.
Yes timber must be dry though
cherry borromeo is on a distinguished road
Send a message via Yahoo to cherry borromeo
Could you please add another information about a stun gun and its purpose.
Cattle mover ,electric fence ,ATM Guard ,Policemans friend (other friend Mace)
You have seen Starsky & Hutch ?--This is Macey & Crutcher
My Property and my Family are not for Govenments to control.That is not the purpose of Governments.
To stop corruption in Government officials give them three times the penalty. They should, and do, know better. Let them commit to that when first employed
tytower is offline
Old 31st March 2008, 12:49 AM   #261
Does this device deliver an incapacitating amount of energy or is it one of those shitty camera flash circuits?
Nooblet is offline
Old 31st March 2008, 01:08 AM   #262
The schematic on the first page of this thread uses a little battery, little transformer, little transistor and no high voltage capacitor. Its shock will feel like a mosquito bite but the tingle will continue. A camera flash produces a powerful shock for a moment from its high voltage capacitor.
It might incapacitate (stun) a mosquito.
audioguru is offline
Old 4th April 2008, 03:53 AM   #263
hi... i build this circuit as part of my project now but i didn't put on the transformer.. and nothing happen when i touch the output... why? and what is the waveform at pin3? monostable or astable? can teach me? because my teacher doesn't teach us anything and ask us to do it... so i need your help...
jonkbu is offline
Old 4th April 2008, 12:31 PM   #264
Didn't you read the text of the project?
It says, "The transformer steps up the voltage to about 1800V".
Look at the datasheet for the LM555. It shows a square-wave output from the same astable oscillator circuit.
Old 4th April 2008, 11:16 PM   #265
Any idea how to measure the voltage and potential current?
I did measuring of the input voltage (14volts) and current (3 amps) and measured the primary vs secondary windings, used that ratio to calculate voltage and current. Is that the only way? There would be losses associated with the coil dropping the output?
Conrad_Turbo is offline
Old 5th April 2008, 12:52 AM   #266
Due to the flyback effect, the output voltage is likely to be over ten times the turns ratio of the coil.
You could stack a hell of a load of high voltage resistors on the output of your multimeter to form a divider but that isn't very accurate since the delivers the power in pulses. You really need to use a scope with a high voltage probe.
if I know the answer.
Hero999 is offline
Old 6th April 2008, 11:52 AM   #267
I am looking to make a UV fly killer, anyone think this is the way to go? I hear alot say its not very powerful etc, but then Im just looking to zap flies
dannix is offline
Old 6th April 2008, 02:51 PM   #268
The Actual output Voltage depends on the length of your spark gap. The Spark gap acts like a Zener Diode.
The Pulsed Current on the output can be measured with a Small Dropping resistor and an Oscilloscope.
chemelec is offline
Old 8th April 2008, 08:15 PM   #269
pls post the PCB and where can be search the transformer, you post image of all circuit, front and rear, thanks!
ggoku2004 is offline
Old 8th April 2008, 09:14 PM   #270
Thanks for the info guys. All I know right now is that it makes a 5000v fence tester smoke, so there is plenty of voltage.
Google the internet. There are plans everywhere.
STUN GUN tripler Electronic Projects Design/Ideas/Reviews 60 13th November 2009 05:47 PM
stun gun farnoosh General Electronics Chat 0 1st June 2004 07:55 AM
stun gun farnoosh General Electronics Chat 0 1st June 2004 07:54 AM
stun gun help dstich Electronic Projects Design/Ideas/Reviews 0 21st May 2004 06:10 PM
Stun gun Arkan Electronic Projects Design/Ideas/Reviews 3 1st March 2004 01:20 PM
