| Electronic Projects A collection of small electronic circuits and projects you can build. |
| | Thread Tools | Search this Thread | Display Modes |
| Experienced Member | I know there have been discussions on these forums of LEDs as light sensors, but I don't remember seeing one used like this. Fig. 1 here is a night light that uses the same LED for sensing and for illumination. I breadboarded it, and it worked. I'm not sure how useful it would be, but it demonstrates the principle nicely. Fig. 2 supposedly works in the opposite fashion, but I didn't test it. EDIT: Here is a more complicated, earlier version of the same idea.
__________________ Ron Last edited by Roff : 21st March 2008 at 10:58 PM. |
| Experienced Member | The Cmos 7555 IC has a current consumption spec that has no note. So it could be with the output high, low or with it actually timing. Cmos logic ICs draw almost no current when their outputs are high or low. The ones with a Schmitt-trigger input draw some current in their input Mosfets when they are active which might also happen in a Cmos 7555.
__________________ Uncle $crooge |
| Experienced Member | I know that, what I was talking about has nothing to do with the power consumption of the IC but the circuit as a whole. You need to look at the bigger picture rather than just what the 7555 is doing. Look at the schematic, R1 and R2 dissipate power even when pin 3 is low. This means the circuit will consume 9/1210 = 7.438mA which is far too high for standby operation. Last edited by Hero999 : 26th March 2008 at 01:09 PM. |
| Experienced Member | Good, you reduces the wasteful current in the resistors. But the battery will still need to be replaced every week and there isn't enough wide-angle light for a night light. It will just be a guiding light like airports use to mark the runways at night for landing aircraft.
| Experienced Member | Quote:
I have several < $ 2.00 LED night lights, they light is greenish in color. And they give off enough light to allow you to move around without bumping into things. Because the light is greenish you can look straight at them at close range and not loose you night vision. Like over the counter in a small bathroom. I have never understood why car headlights are white and not blue! :-) | |
Don't you think I know the difference? Maybe the light is more blue. I know the ones you are talking about but that is NOT what I am talking about. I forgot to mention the obvious that they have diffusers on them. I have lived with them for several years now and they are great. | |
So stick a diffuser on the end or the LED and use a nice and chunky 6V SLA battery to power it. | |
Here is a picture of what I am using. There are several different diffuser designs. http://www.pbase.com/sinoline/image/94748057 I have blown up part of the text on the packaging for the doubters. Last edited by Rolf : 26th March 2008 at 10:12 PM. | |
| 230 Volts LED night light project | RODALCO | Electronic Projects Design/Ideas/Reviews | 12 | 2nd March 2008 11:43 PM |
| LED christmas light switch (what would you call a circuit like this?) | Andy1845c | General Electronics Chat | 14 | 1st December 2007 03:24 PM |
| LED to light when load detected? | NewUser | General Electronics Chat | 5 | 5th October 2007 10:28 AM |
| Help with night light system | ZackSmith | Electronic Projects Design/Ideas/Reviews | 1 | 30th October 2006 08:38 AM |
| looking for circuit that turns light on at night off during day | mettam | Electronic Projects Design/Ideas/Reviews | 15 | 5th September 2006 03:30 PM |
