| | #16 | |
BTW how it appears as a post and with an overall of 12 posts above it afresh Sir? It was an item with 11 or 12 replies over that at the time I saw it .
| | #17 |
| It re-appeared because someone (firoz3321) posted a reply in the thread.
| | #18 |
| OK I got it.
| | #19 |
could this be used to magnify the signal of my ipod's fm tuner? it cuts out at times.
| | #20 | |
You have a receiver problem that should be in its own thread. Phone your radio station and ask them to boost their power so that your cheap or defective radio can pick them up without cutting out. Good luck.
| | #21 | |
haha, no no i have a tuner so i can listen to my ipod in the car. it plugs into a cigarette lighter and i sync the frequency so it'll play out of the car speakers. but it'll cut out at times, sometimes causing me to surf for another channel that i can set it to. | ||
| | #22 |
| Car radios have an antenna outside the car. Your ipod tuner doesn't. Get a car radio with an antenna outside.
| | #23 | |
Either on the Ground to antenna or pole connection or just a poor receiver. kv
__________________ Truthiness Monkeys : Obedience, Ignorance, Fear. | ||
| | #24 |
| Not sure about this one, but silicon chip did one of a similar design that was sold in a kit form at one of the local electronic kit retailers here in Aust. I think it was in their Nov 89 issue. It ran off 2 X 1.5V batteries, and the output coil was actually etched into the PCB rather than wound. It got a range of about 100m from memory, and fitted into a match box, complete with batteries. I hooked one up to a 9V battery, and it was good for 500m, and that's only the point at which I turned the car around and went home again. | |
| | #25 | |
If you wanted Stereo, perhaps Micromitter of silicon chip is the best and One "AN920" has suggested specific mods for improving unwanted Noisy tone comming at higher end of audio. you may implement that. Once you want Mono, i feel MOD4 is superior by any means.
| | #26 |
Ramsey Electronics sells a FM Transmitter kit with an external antenna connector to create a greater spread. Ramsey Electronics However, it's a battery hog with an external coupler | |
| | #27 |
hello,i need to know a circuit of an AM transmitter please.
| | #28 |
There are some AM transmitter circuits on the internet. I entered AM Transmitter Circuit in Google and got pages of circuits. 129,000 links.
| | #29 |
please specify the websites for doing electronics mini projects
| | #30 |
Can anyone provide me a circuit for a TV Transmitter which can radiate the signal to a distance of 3 to 5 Kilo meter either in VHF or UHF.
| simple, transmitter |
| Simple transmitter and reciever schematic | D.J. | Electronic Projects Design/Ideas/Reviews | 15 | 28th May 2009 12:58 PM |
| Simple AM transmitter | George L. | Electronic Projects Design/Ideas/Reviews | 23 | 23rd December 2006 05:27 AM |
| Simple audio Transmitter | windozeuser | General Electronics Chat | 5 | 6th March 2006 08:44 PM |
| Simple Data Transmitter Circuit | Iceman_Chris | Electronic Projects Design/Ideas/Reviews | 14 | 9th August 2005 09:10 PM |
| simple transmitter & receiver | jayman | Electronic Projects Design/Ideas/Reviews | 1 | 20th October 2003 05:07 PM |
