| Electronic Projects A collection of small electronic circuits and projects you can build. |
| Project Level: Intermediate Here is a simple 10 channel light bulb sequencer circuit which you can build up to decorate your house. OPERATION The circuit consists of 2 sections: 1) Oscillator: The oscillator is built around IC555 wired in astable mode. The frequency of this oscillator is around 1 Hz (or slightly less than that) which can be increased further by decreasing the value of potentiometer VR1. The oscillator frequency determines the speed of effect. Higher the frequency, higher will be the effect speed. 2) Sequencer circuit: The sequential lighting of bulbs is achieved using Jhonson Counter IC 4017 which has 10 decoded outputs. The output of 4017 increments by one on rising edge of each clock pulse from IC555. In the circuit the fifth output Q4 of 4017 is connected to its reset pin to reset the sequence after every four clock pulses. Here only four channels are shown but it can be extended upto 10 channels using all the outputs of 4017. In this case the reset need to be connected to Ground. For channels less than 10 the output one greater than required number of channels should be connected to reset pin to reset the cycle as soon as counter counts one greater than the required channels. The output of 4017 drives the base of NPN transistors (BC547) through 1k resistors. The LED in the collector loop of each transistor indicates the active channel. The emitter current of each transistor further drives the gate of Triacs (BT139) thereby turning them ON and supplying power to the lamp loads. Those who have 120V AC mains in their countries can also use this circuit without any changes. Many number of bulbs can be connected in parallel on each channel provided the maximum load on each channel does not exceed 3500W for 220V operation and 1760W for 110V operation. :arrow: NOTE: DO NOT TOUCH ANY COMPONENT OF THE CIRCUIT WHEN IT IS ACTIVE AS IT MAY BE AT A VERY HIGH POTENTIAL AND MAY PROVE FATAL. I DO NOT GIVE GURANTEE OF ANY KIND. EXPERIMENT AT YOUR OWN RISK. Feel free to give your feedback!
__________________ "There is no way to peace, peace is the way!" | |
I don't see any optoisolat for your circuit.......it is ok?
__________________ life is so short, don\'t waste your time dude | |
| | #3 | |
nice project kinjalgp!
__________________ ▌ Electro Tech Online Owner ▌ Need to contact me? Send me a Private Message. ▌ Verification Email didn't arrive? See this thread. | |
Thanks Electromaster! It seems you saw this project 2 years after posting! :lol:
| | #6 |
arrr!!! no now i remember you posting it!!! I just saw it back on top and I thought it was another... ops: Memory must be slipping in my old age :wink:
| | #7 |
nice post thanks its useful for me i used some part of your circuit in another project thanks.... | |
| | #8 |
thanks dsf
| | #9 |
Can i replace the BT139 with T106M1 and which one is the better Thanks | |
| | #10 | |
__________________ "There is no way to peace, peace is the way!" Last edited by kinjalgp; 29th July 2007 at 12:38 AM. | ||
| | #11 |
Is there a reason that you are switching the neut with the BT139? Can I switch the Hot? This project is just what to doctor ordered!!
| | #12 |
another lesson for new member, like me. but i like this project.
__________________ Visit my project mides Last edited by jumides; 24th December 2007 at 08:09 AM. | |
| | #13 |
can u plz give te schematic diagram of ur project?
| | #14 | |
__________________ "There is no way to peace, peace is the way!" | ||
| | #15 | |
I see schematic, but what happen to 4017, if BT139 goes wrong(short circuit) ?.
__________________ Visit my project mides | ||
