Old 27th October 2008, 02:19 AM   #46
Originally Posted by Disco Elephant View Post
I can't see why a light globe would go short circuit when the filament breaks. How can there be a low impedance between the 2 contacts if the only part that could possibly cause a short is the filament, which is resistive. Nigel, if you could explain the mechanism that causes the light globe to become a short circuit, it could well clear up a lot of confusion.
Nigel does not know, he has only theories based on his experience as a small appliance repair tech. It is much more likely that when the filament breaks initially the coiled coil filament falls down to make connection at say half the filament length, drawing considerably more power until it finishes vaporizing.
The result is obviously not a direct short. Every one familiar with the old C7 Christmas tree bulbs can think back to clipping an out bulb and having it come back for a while brighter than the rest.
3. Is it possible that the reason you see a lot of professional lighting equipment with a blown globe and a dead triac is because the globe failed and was never replace, and sometime later the triac, which is driving several other globes, failed for a completely unrelated reason? From what I've seen, as the number of lights in a lighting system increases, so too does the probability of having a blown globe, so I think this is possibly the reason why you see lots of dead triacs connected to blown globes. But that's really nothing more than an educated guess.
I will stand by my statement that improper design and application cause the triacs to be susceptible to the aforementioned effect.
Ubergeek63 is offline
Old 27th October 2008, 02:58 AM   #47
I'm going to jump in here, and say that you both (Nigel & Uber) are right.
While I was stationed in Germany (U.S. Army), I was technical director for the local Moral Support Activities branch. My job entailed maintenance and repair of all of the electronic equipment. Among all the varied types were several triac controlled light boards. The lights used most often with these boards were par 36, par 38 and par 64.
Like Nigel, I replaced many triacs in the control boxes, and most failures happened when a bulb blew, but NOT ALWAYS. I'm guessing about 30% of the time it was due to overloading of the channel, and probably 45% due to bulb failure. The rest could be attributed to other causes, such as power spikes and drop-outs.
However, the failure rate was actually quite low, I replaced maybe 10 triacs during the three years I held that post, out of a possible 100 units.
charlie_r is offline
Old 27th October 2008, 10:30 PM   #48
Discrete semiconductors is certainly not my strong point, here's my opinion on the whole matter.
Triacs cost less than £1 each, so wouldn't mounting them into a socket instead of fixing them in place be a much better idea? So when it does break, you could just yank it out and throw another one in.
when you post that reply, im just kidding.
danielsmusic is offline
Old 28th October 2008, 01:58 AM   #49
They do not generally blow. It is just much more common to be either overloaded or not heat sunk properly.
Now if it is an inductive load it is an entirely different story... but still the failure is non destructive, it simply does not turn off at the end of the cycle.
Old 7th December 2008, 10:23 PM   #50
Thanks but this circuit without any isolat
monemhabashy is offline
Old 8th December 2008, 05:26 AM   #51
You don't need isolation unless you like to touch live circuits
kinjalgp is offline
Old 21st December 2008, 07:01 PM   #52
i like your project. thanks
Emmanuel K is offline
Old 22nd December 2008, 12:50 AM   #53
Sorry I missed this before. I stand by my statement: only an over stressed triac will blow and the chances are they are not properly heat sunk.
These testosterone laden color organs hopefully use at least 15A triacs in them. The fact of the matter is that triacs typically handle 10x their rated current for an entire power line half cycle safely and that much current readily vaporizes what is left of the failing bulb.
Dan
Old 22nd December 2008, 12:54 AM   #54
you can not socket them. 10-20A and the high temeratures that are developed in even a properly applied power component lead to the failure of the connector.
Dan
Old 27th January 2009, 11:46 PM   #55
i like this project.
knaaphix is offline
Old 1st March 2009, 04:09 PM   #56
Updated schematic for this thread:
Shaded text reads:" original design used a 27K resistor for R2, circuit worked as low as -35C windchill. Lamp outputs are fused for personal safety."
shokjok is offline
