| | #16 | |
To avoid triac failure, never connect load beyond its rated capacity.
__________________ "There is no way to peace, peace is the way!" | ||
| | #17 | |
Bit difficult for a light sequencer though?. | ||
| | #18 |
The 4017 would quickly self-destruct. I built a similar circuit using MCT2 optos and T106 triacs to control Christmas lights ( up to 200 per triac, fused). A smaller version using 2N3904s alone turned on LEDs as a mini name-in-lights project, with 6 recipients.
| | #19 | ||
I doubt if that would happen ! When bulb fails, it becomes open circuit ! How will that affect the TRIAC ?? I have been using this circuit for years now with quite a lot bulb failures, never had to replace a TRIAC or 4017 yet! Can you explain ?
__________________ "There is no way to peace, peace is the way!" Last edited by kinjalgp; 22nd May 2008 at 04:57 AM. | |||
| | #20 |
I’m away of this BT series TRIACs. For running lights its ok but when it comes to sensitive light dimming (Phase Controlling) this series acts poor. I’m using TIC216 or BTA16-600B because they don't seem to suffer from any dv/dt problems. | |
| | #21 | |
| | #22 |
May I suggest a safer circuit, built 20 years ago and still functions.
| | #23 |
Thats pretty dang cool! Its next on my boredom list.
| | #24 |
Hi folks, First time poster. I'm looking for help on a light sequencer. But since I'm electronically inept, I was hoping someone could point me in the direction of where to purchase one. I am setting up my lighting effects for Halloween and have several lights (light bulbs and floods) I need to manage. Thanks! | |
| | #25 | |
Another way to look at it would be that you have a military type of design and what Nigel sees is cut rate crap manufactured in China. While the bulbs do tend to short before they open, triacs have a tremendous surge rating that handles it fine. Were it not so there would be no market for triac lamp dimmers. Last edited by Ubergeek63; 14th October 2008 at 10:43 PM. | ||
| | #26 |
| Certainly not military grade, but certainly professional and semi-professional grade, used for light shows in clubs and disco's. You don't really get anything similar in consumer electronics?.
| | #27 | |
It is more likely in that case to be frayed wires shorting out or under rated triacs in that case. Clubs are likely to be moving things around or putting in over size bulbs bulbs for effect. | ||
| | #28 | |
![]() This is an EXTREMELY common and well known problem, with fuse manufacturers even bringing out special highly expensive fuses to try and reduce the problem. Do you have MCB's rather than fuses at home?, it's commonplace for the MCB to trip out if a bulb blows, same thing - high current surge takes it out. Last edited by Nigel Goodwin; 18th October 2008 at 02:17 PM. | ||
| | #29 |
US ... Almost everything here is circuit breakers, but they don't blow either. How often do you hear of wall lamp dimmers blowing out? That would be the real difference between an overloaded or crappilly designed triac circuit blowing and what you are seeing. If it was that properly designed and rated triac circuits were blowing out all the time you would be hearing of people replacing their wall dimmers all the time. | |
| | #30 | |
![]() Completely different things, and the lamp failure rate is massively different. Incidently, if it's of any help to you?, TRIAC's used are generally TO220 rated at 8A continuous, with a maximum 4A load per channel (1000W per channel) for a 3 channel unit, correspondingly less as you get more channels (as there's a 3000W total capability). | ||
