Notices
Old 9th August 2007, 01:26 PM   (permalink)
Experienced Member
hotwaterwizard is just really nicehotwaterwizard is just really nicehotwaterwizard is just really nice
Send a message via AIM to hotwaterwizard Send a message via Yahoo to hotwaterwizard
Originally Posted by Oznog
Regulators CANNOT be put in parallel to increase their rating. One will usually end up taking all the current.
Hmmm, If this is completely true explaine these articles.
http://www.elecdesign.com/Articles/A...9270/9270.html
http://www.edn.com/index.asp?layout=...cleid=CA434875
http://www.edn.com/contents/images/72204di.pdf
John DeRosa (Hotwaterwizard)
hotwaterwizard@aol.com
hotwaterwizard is offline   Reply With Quote
Old 9th August 2007, 01:43 PM   (permalink)
Experienced Member
audioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to behold
The article says that current sharing is poor unless resistors or diodes are added in series with the outputs of the regulators. The article says that current-sharing resistors cause a voltage drop of 1.5V at full load so the excellent voltage regulation of the ICs is ruined.
Old 9th August 2007, 09:17 PM   (permalink)
Experienced Member
I'd just stick them in parallel (without any series resistors) if I were you.
Most voltage regulators lower the voltage and are protected from thermal run-away. For small loads the strongest regulator will source all the current, as the load current increases it will start to shut down and the slightly weaker regulators will provide the current.
Old 10th August 2007, 01:54 AM   (permalink)
Experienced Member
mneary is a glorious beacon of lightmneary is a glorious beacon of lightmneary is a glorious beacon of lightmneary is a glorious beacon of lightmneary is a glorious beacon of light
Send a message via AIM to mneary
I'd be concerned about the long term reliability of a regulator constantly in thermal limiting mode. If it's for hobby, might be OK - just keep curious fingers off the hot surfaces (they'll be around 100c). It's certainly expedient if you're just building one of them.
You might encounter stability problems which will be highly annoying if you don't have the skills to troubleshoot and fix.
Over the long term, you'll learn to design a proper power supply with an adequate heat sink. It might not be necessary to do it now.
mneary is offline   Reply With Quote
Old 11th August 2007, 05:45 PM   (permalink)
Experienced Member
mvs sarma is a name known to allmvs sarma is a name known to allmvs sarma is a name known to allmvs sarma is a name known to allmvs sarma is a name known to allmvs sarma is a name known to all
Send a message via MSN to mvs sarma Send a message via Yahoo to mvs sarma
Hi Chandu,
did you really go thro the applications of 7812 fir high current with short circuit protection -- these are well described in the datasheet also. First priority if can source is LM350(TO3) as suggested by Hotwaterwizard-
if 7812 is preferred to be used, try to follw the high current application.
It is better not to go for paralleled regulators-drawbacks indicated by AudioGURU- and land into complication and non-comletion of the project.
Sarma
mvs sarma is offline   Reply With Quote
Old 11th August 2007, 09:03 PM   (permalink)
Experienced Member
L7812CV
What is wrong with the circuit on page 29 of the Datasheet?
Datasheet
CLICK HERE for Datasheet
Product Page
CLICK HERE Product Page
Old 12th August 2007, 05:12 AM   (permalink)
Experienced Member
Fig22 indicated by Hotwaterwizard is fine and i was using one and it worked well
Sarma
Magnets and Electromagnets ElectroMaster Electronic Theory 11 27th November 2007 02:31 PM
Describe whats going on in this circuit tru_cutru General Electronics Chat 24 1st June 2007 01:13 AM
Heavy current high speed switching jbelectric777 Electronic Projects Design/Ideas/Reviews 14 19th May 2007 05:34 PM
Current and Conductivity ElectroMaster Electronic Theory 1 2nd February 2007 12:49 PM
Need Help on High Current H Bridge pidot Robotics Chat 16 15th September 2005 06:46 AM
