| Electronic Projects A collection of small electronic circuits and projects you can build. |
| | #16 | |
http://www.elecdesign.com/Articles/A...9270/9270.html http://www.edn.com/index.asp?layout=...cleid=CA434875 http://www.edn.com/contents/images/72204di.pdf | ||
| | #17 |
The article says that current sharing is poor unless resistors or diodes are added in series with the outputs of the regulators. The article says that current-sharing resistors cause a voltage drop of 1.5V at full load so the excellent voltage regulation of the ICs is ruined.
| | #18 |
I'd just stick them in parallel (without any series resistors) if I were you. Most voltage regulators lower the voltage and are protected from thermal run-away. For small loads the strongest regulator will source all the current, as the load current increases it will start to shut down and the slightly weaker regulators will provide the current.
| | #19 |
I'd be concerned about the long term reliability of a regulator constantly in thermal limiting mode. If it's for hobby, might be OK - just keep curious fingers off the hot surfaces (they'll be around 100c). It's certainly expedient if you're just building one of them. You might encounter stability problems which will be highly annoying if you don't have the skills to troubleshoot and fix. Over the long term, you'll learn to design a proper power supply with an adequate heat sink. It might not be necessary to do it now. Last edited by mneary; 10th August 2007 at 02:58 AM. | |
| | #20 |
Hi Chandu, did you really go thro the applications of 7812 fir high current with short circuit protection -- these are well described in the datasheet also. First priority if can source is LM350(TO3) as suggested by Hotwaterwizard- if 7812 is preferred to be used, try to follw the high current application. It is better not to go for paralleled regulators-drawbacks indicated by AudioGURU- and land into complication and non-comletion of the project. Sarma | |
| | #21 |
L7812CV What is wrong with the circuit on page 29 of the Datasheet? ![]() Datasheet CLICK HERE for Datasheet Product Page CLICK HERE Product Page Last edited by hotwaterwizard; 11th August 2007 at 10:12 PM. | |
| | #22 |
Hi, Fig22 indicated by Hotwaterwizard is fine and i was using one and it worked well Sarma | |
| current, high |
| Need Help on High Current H Bridge | pidot | Robotics Chat | 19 | 12th November 2008 09:10 AM |
| Magnets and Electromagnets | ElectroMaster | Electronic Theory | 11 | 27th November 2007 03:31 PM |
| Describe whats going on in this circuit | tru_cutru | General Electronics Chat | 24 | 1st June 2007 02:13 AM |
| Heavy current high speed switching | jbelectric777 | Electronic Projects Design/Ideas/Reviews | 14 | 19th May 2007 06:34 PM |
| Current and Conductivity | ElectroMaster | Electronic Theory | 1 | 2nd February 2007 01:50 PM |
