Old 16th July 2007, 12:48 AM   #1
Default Vehicle Loop Detector
I Just Updated my Car Detector project, Should anyone here need one.
http://www3.telus.net/chemelec/Proje...p-Detector.htm
Have Fun...Gary
I No Longer accept Private Messages on here.
All Emails to me Must Contain the Word \"Electronic\" in the \"Subject Line\"
or they go Directly to my Junk Mail Folder.
Email me at: chemelec@hotmail.com
Website: http://www3.telus.net/chemelec
chemelec is offline
Old 24th July 2007, 10:11 PM   #2
Thanks! I might be putting something like this in my driveway and tie it to some outside lighting.
Conrad_Turbo is offline
Old 26th July 2007, 10:25 AM   #3
that good staf
wizy is offline
Old 24th October 2007, 02:16 AM   #4
Just a question, but how do you make the coil? I know it says it has to be 4 - 6 feet in Diamater, and about 3 - 4 turns, but how do you make that? Do you get something that is 4 - 6 feet in diamater, and just wrap wire around it?
Thanks.
Hydrogenboy is offline
Old 24th October 2007, 03:28 AM   #5
It Doesn't have to be That Size, But for detecting a Car, that works good.
One Way to wind the coil: just stick some wooden sticks in the ground, with a spacing as needed, than wind the coil around them to make that diameter of a coil. When finished, tape the wires to hold them together and remove the sticks.
Or if you want to try a smaller coil, wind it loosly around a Garbage can, than tape the wires together so thay stay as a coil and remove it from the can.
For a Smaller Coil like this, You might need 10 to 15 turns.
Hope this helps.....Gary
Thanks.
chemelec is offline
Old 24th October 2007, 09:40 PM   #6
Yes, it helps.
Thanks.
Old 27th October 2007, 06:11 PM   #7
This is interesting. I always wondered about those marks on the asphalt road at the crossings. Would be very interesting to build similar systems.
Thanks for this project.
Intellin.org Get good electronic circuits reference books.
reyarba is offline
Old 30th October 2007, 02:28 AM   #8
Another question (yes I ask alot!) Does the wire have to be stripped, or can it be insulated?
Thanks.
Old 30th October 2007, 02:51 AM   #9
Definitely insulated! Preferably placed inside plastic conduit or something similar if you intend to bury it in the ground.
kchriste is online now
Old 30th October 2007, 05:06 AM   #10
Any Vinal Covered wire is OK, Just buried as is.
(Like a 16 or 18 gauge Solid house wire is good.)
chemelec is offline
Old 30th October 2007, 07:48 AM   #11
How are the magnetometer sensors used in some vehicle detector systems constructed? An example is:
http://www.smarthome.com/7313.html
What goes in the PVC pipe?
Wally
wmerrin is offline
Old 30th October 2007, 02:35 PM   #12
Wally
Forget the PVC Pipe. It is NOT NEEDED!
Magnetometers use a "Hall Effect" Device to detect Magnetic Field Changes.
This is considerably Different from my system and not very easy to build for the average person.
chemelec is offline
Old 3rd November 2007, 02:44 PM   #13
ya its great!!!!!
praveen kumar singh is offline
Old 30th August 2009, 08:30 AM   #14
Default Coil loop inductance
What inductance are we looking at on this coil? I am making a mini version of this. Like a few inches, somehow I cannot get it to work.
yehey is offline
Old 30th August 2009, 02:22 PM   #15
Aproximately 18uH.
chemelec is offline
detector, loop, vehicle
calculator sara_6252 Micro Controllers 8 1st June 2007 03:29 AM
LCD Alarm clock with PIC16F877 ( some pics included ) pasanlaksiri Micro Controllers 10 22nd May 2007 11:36 PM
infrared detector of unknown spec and origin kelangfei General Electronics Chat 1 2nd May 2007 01:07 PM
Envelope Detector ThermalRunaway General Electronics Chat 13 30th July 2005 07:25 PM
vehicle tracking sanjay79 Electronic Projects Design/Ideas/Reviews 3 10th January 2004 10:54 PM
