Old 13th September 2009, 04:22 AM   #16
A better way to make really BIG buried coils is to get some multi strand data cable, and just connect all the conductors in series.
That way, the underground loop is already waterproof, only the ends where all the connections are, needs to be protected.
And that can be above ground, or even indoors.
Warpspeed is offline
Old 14th September 2009, 07:29 AM   #17
thanks it would really help... nice one
butyokz is offline
Old 22nd October 2009, 10:55 PM   #18
Why stop there?
A smaller version that could use inductance changes to detect a person would make for a really useful way of controlling garden path lights.. or even maybe dance floors...think Michael Jacksons 'Bille Jean' video.
The Mad Professor is offline
Old 23rd October 2009, 09:16 PM   #19
The vehicle detector may work but the output of the LM393 is not connected to the LED correctly. The whole circuit could be done much simpler with a 74c14. A 4 turn coil 6feet diameter will be about 60uH not 18 uH as you suggest. Using 60uH coil and 470n capacitor produces resonance at approx 30kHz.
colin55 is offline
Old 10th November 2009, 03:25 PM   #20
Default Lm392n
I am fairly new to the electronics projects scene, this project looks good, I am finding it a little difficult to find a LM393, but have found a LM392N which seems to have the same pin outputs. Does anyone know whether I could use this instead of the 393, or a good electronics supplier in the UK?
Thanks!
Max
maxmcp is offline
Old 10th November 2009, 04:48 PM   #21
Default Relay
One other thing that I am not sure of, and was wondering how other people have solved the problem; I would like to replace the LED with a relay to operate anything I wanted to, but this is presumably going to draw a different current, do you just adjust the 1K2 resistor to suit?
Thanks!
maxmcp is offline
Old 11th November 2009, 03:21 PM   #22
Thanks!
The LM393 is Very Common, But Yes, The LM392 should work.
(Sorry I don't have an LM292 to actually test it.)
Here is a Modified Schematic for a Relay.
http://www3.telus.net/chemelec/Proje.../Loop-Sch2.png
Gary
I No Longer accept Private Messages on here.
All Emails to me Must Contain the Word \"Electronic\" in the \"Subject Line\"
or they go Directly to my Junk Mail Folder.
Email me at: chemelec@hotmail.com
Website: http://www3.telus.net/chemelec
Last edited by chemelec; 11th November 2009 at 04:14 PM. Reason: Corrections and Updates
chemelec is offline
Old 13th November 2009, 02:15 PM   #23
Question Vehicle Loop Detector
i want to know, in vehicle loop detector give me specifications of LM 393 IC....
that means tell me which comparator will be used here????
plz do help rgt nw!!!!
amit verma is offline
Old 13th November 2009, 03:32 PM   #24
The LM393 is Just a Comparator IC.
In this Circuit, the LM393 Compares the Rectified DC Voltage to the Referance Voltage, created across the Foreward Biased Diode.
ANY Comparator IC can be Used, If you wire it Correctly.
chemelec is offline
Old 14th November 2009, 01:12 PM   #25
Thanks very much, I'll let you know how it goes!
maxmcp is offline
detector, loop, vehicle
calculator sara_6252 Micro Controllers 8 1st June 2007 03:29 AM
LCD Alarm clock with PIC16F877 ( some pics included ) pasanlaksiri Micro Controllers 10 22nd May 2007 11:36 PM
infrared detector of unknown spec and origin kelangfei General Electronics Chat 1 2nd May 2007 01:07 PM
Envelope Detector ThermalRunaway General Electronics Chat 13 30th July 2005 07:25 PM
vehicle tracking sanjay79 Electronic Projects Design/Ideas/Reviews 3 10th January 2004 10:54 PM
