| Electronic Projects A collection of small electronic circuits and projects you can build. |
| I want to implement a receiver to get only the time signal from WWW (10 MHz). Proof of a concept is the goal. Since it is not the main point in my project I am looking for a "sure fire" circuit not needing more than the usual debugging. I run across one here: http://www.qrp.pops.net/wwv_receiver.asp My questions: A) Dual MOSFET 40673 transistors are discontinued ones, not obtainable locally and hard to get (time and $$$$$$$$). Is it any modern one which I could use to replace them in the front end section?. B) Regarding the ferrite toroids I have in my junkbox: how could I know if any one match the reccomended ones? C) Is there any reason to use such an elaborate audio amplifier circuit or could it be replaced by something based on a audio amp IC? D) Can anyone suggest another circuit, similar or SIMPLER, which I could build but "sure fire" granted? Please do not propose alternatives other than RF receivers. Proof of the concept in play requires it! (Yes I know that GPS exists. I really know that!) My RF practice is lost in time and have not time nor interest in experimenting. At least not this time. Thanks for any help. I will certainly appreciate that.
__________________ Agustín Tomás In theory, there is no difference between theory and practice. In practice, however, there is. | |
I think that this example circuit that you propose is too complicated for the basic job it must do, and if you want it bulletproof you should avoid a TRF receiver of this type. The most reliable and sure-fire receiver architecture is the super-heterodyne. That is why it is the most popular configuration. You might want to consider using a single chip AM receiver suited to 10MHz operation. I googled and found one or two examples that include application circuits: http://www.shfmicro.com/TEA5551T.pdf or http://www.nxp.com/acrobat_download/...072A_CNV_2.pdf (althought the TDA1072 doesn't mention an input frequency range to 10MHz so not sure it is good).
__________________ RadioRon | |
Hi Agustín, First question: See what you can find, if it has two gates it will do. BF961's and BF981's will probably work even better than the 40673's. Second question: None of the toroids in your junkbox are suitable, that's why it's called the junkbox. The T-cores are metal powdered cores, the FT-cores are ferrite cores. http://www.amidon-inductive.com/aai_specifications.htm Third question: You don't actually need the audio amplifier, get the circuit working and decide later if you want to add one. This is what a T50-2 looks like. on1aag. | |
Are you expecting a good signal most of the time? You're a long way from Colorado Springs....
| mhz, receiver, signal, time, www |
| The Oscilloscope | ElectroMaster | Electronic Theory | 12 | 3rd February 2008 02:45 PM |
| Using Oscilloscopes | mechie | Electronic Theory | 9 | 29th November 2007 10:49 PM |
| Satellite signal time shifting | wayneevanb | Electronic Projects Design/Ideas/Reviews | 2 | 24th May 2004 02:18 PM |
| Yet another LED taillight controller...... | NickK | Electronic Projects Design/Ideas/Reviews | 1 | 31st March 2003 06:38 PM |
| I NEED HELP! HOW DO I MOD. A UHF 2 CHANNEL RECEIVER ...... | JC | Electronic Projects Design/Ideas/Reviews | 1 | 1st March 2003 11:48 AM |
