Notices
Old 5th July 2007, 08:03 PM   (permalink)
Experienced Member
atferrari is on a distinguished road
Default 10 MHz only WWW time signal receiver
I want to implement a receiver to get only the time signal from WWW (10 MHz). Proof of a concept is the goal.
Since it is not the main point in my project I am looking for a "sure fire" circuit not needing more than the usual debugging.
I run across one here: http://www.qrp.pops.net/wwv_receiver.asp
My questions:
A) Dual MOSFET 40673 transistors are discontinued ones, not obtainable locally and hard to get (time and $$$$$$$$). Is it any modern one which I could use to replace them in the front end section?.
B) Regarding the ferrite toroids I have in my junkbox: how could I know if any one match the reccomended ones?
C) Is there any reason to use such an elaborate audio amplifier circuit or could it be replaced by something based on a audio amp IC?
D) Can anyone suggest another circuit, similar or SIMPLER, which I could build but "sure fire" granted?
Please do not propose alternatives other than RF receivers. Proof of the concept in play requires it!
(Yes I know that GPS exists. I really know that!) My RF practice is lost in time and have not time nor interest in experimenting. At least not this time.
Thanks for any help. I will certainly appreciate that.
Agustín Tomás
In theory, there is no difference between theory and practice. In practice, however, there is.
atferrari is offline   Reply With Quote
Old 5th July 2007, 10:31 PM   (permalink)
Experienced Member
RadioRon is just really niceRadioRon is just really niceRadioRon is just really nice
I think that this example circuit that you propose is too complicated for the basic job it must do, and if you want it bulletproof you should avoid a TRF receiver of this type. The most reliable and sure-fire receiver architecture is the super-heterodyne. That is why it is the most popular configuration.
You might want to consider using a single chip AM receiver suited to 10MHz operation. I googled and found one or two examples that include application circuits:
http://www.shfmicro.com/TEA5551T.pdf
or
http://www.nxp.com/acrobat_download/...072A_CNV_2.pdf
(althought the TDA1072 doesn't mention an input frequency range to 10MHz so not sure it is good).
RadioRon
RadioRon is offline   Reply With Quote
Old 5th July 2007, 11:41 PM   (permalink)
Experienced Member
on1aag is a jewel in the roughon1aag is a jewel in the rough
Hi Agustín,
First question: See what you can find, if it has two gates it will do.
BF961's and BF981's will probably work even better
than the 40673's.
Second question: None of the toroids in your junkbox are suitable, that's
why it's called the junkbox.
The T-cores are metal powdered cores, the FT-cores
are ferrite cores.
http://www.amidon-inductive.com/aai_specifications.htm
Third question: You don't actually need the audio amplifier, get the
circuit working and decide later if you want to add one.
This is what a T50-2 looks like.
on1aag.
on1aag is online now   Reply With Quote
Old 6th July 2007, 01:16 AM   (permalink)
Experienced Member
mneary is a glorious beacon of lightmneary is a glorious beacon of lightmneary is a glorious beacon of lightmneary is a glorious beacon of lightmneary is a glorious beacon of light
Send a message via AIM to mneary
Are you expecting a good signal most of the time? You're a long way from Colorado Springs....
mneary is offline   Reply With Quote
The Oscilloscope ElectroMaster Electronic Theory 12 3rd February 2008 01:45 PM
Using Oscilloscopes mechie Electronic Theory 9 29th November 2007 09:48 PM
Satellite signal time shifting wayneevanb Electronic Projects Design/Ideas/Reviews 2 24th May 2004 01:18 PM
Yet another LED taillight controller...... NickK Electronic Projects Design/Ideas/Reviews 1 31st March 2003 05:37 PM
I NEED HELP! HOW DO I MOD. A UHF 2 CHANNEL RECEIVER ...... JC Electronic Projects Design/Ideas/Reviews 1 1st March 2003 10:47 AM
