Notices
Old 28th May 2007, 12:21 AM   (permalink)
Experienced Member
Rolf is on a distinguished road
Send a message via Skype™ to Rolf
Talking Simplest of all; Paper sensor.......
Originally Posted by joecool85
Sort of, ideally it will never be submerged. I'm putting mine next to my sump pump, and unless I have a sump failure (it does happen every so often) they won't get wet. But the few times they do shouldn't create a lot of corrosion. Also, even with corrosion, this circuit should function fine as it isn't horribly critical what the resistance is between the two probes as long as there is some. I tried it with filtered water from the sink and it worked still! Heck, even moist fingers set it off.
I guess it is a little difficult resetting this one:
http://www.pbase.com/sinoline/simple_moisture_sensor
But I am sure that could be worked out, because I have.
Rolf is online now   Reply With Quote
Old 28th May 2007, 01:52 AM   (permalink)
Experienced Member
Leftyretro has a spectacular aura about
While I agree about the floater being better for multiple fluid types, I designed this for water and only water. Hopefully that would be the only fluid flooding out my basement.
Of course water is probably all your basement will ever see, but think about long term reliablity and ease of testing, fewest components, etc. This kind of application can help save you a ton of $$ in damage and the the sensor portion needs to be as failsafe as you can come up with. I still vote the simple float switch if it was my basement. Basements are rare in California but sump alarms are common.
Now what I need is an earthquake alarm circuit that gives about 5 mins warning of a big one
Lefty
Leftyretro is offline   Reply With Quote
Old 28th May 2007, 01:57 AM   (permalink)
Experienced Member
joecool85 is on a distinguished road
Send a message via AIM to joecool85
Lefty
I trust my circuit. Besides, I'm living in an apt and my landlord didn't find it necessary to install an alarm, so I made one.
Life is what you make it.
joecool85 is offline   Reply With Quote
Old 28th May 2007, 02:03 AM   (permalink)
Experienced Member
Default I would like to see.............
{snip}I still vote the simple float switch if it was my basement. Basements are rare in California but sump alarms are common.
{snip}
Lefty
So if you don't have a sump pump; where do you find a float switch that operates in a (aprox) 0.01" of water? After all you do want an alarm that senses the very appearance of water.
Old 28th May 2007, 02:18 AM   (permalink)
Experienced Member
Well never owning a basement, I don't know their normal drainage management. Is there no normal exit for water? If the floor is completely sealed then I guess one would need to find the lowest spot (unless non-slopped and perfectly level) and utilize something other then a float switch of course..
Lefty
Old 29th May 2007, 04:35 AM   (permalink)
Experienced Member
Sceadwian is just really niceSceadwian is just really niceSceadwian is just really nice
Send a message via AIM to Sceadwian Send a message via Yahoo to Sceadwian
Floats are more reliable than oxidizeable electrical contacts. Float activated relays are widely used in both industrial and home situations. We have several pumps at work that have built in floats for exactly this purpose. You just put them in a hole in the floor where water drains and give it enough space on all sides and as long as you check the mechanicals every 6 months to make sure nothing rusted or was blocked you never have to worry about it.
Curiosity killed the cat; That's why they have nine lives.
Old 29th May 2007, 01:11 PM   (permalink)
Experienced Member
Default Set me straight ............
Originally Posted by Sceadwian
Floats are more reliable than oxidizeable electrical contacts. Float activated relays are widely used in both industrial and home situations.[snip]
Are you referring to the sensing contacts in the original circuit? They should not be subject to much humidity like a switch in a partial water filled hole.
Old 29th May 2007, 06:03 PM   (permalink)
Experienced Member
j.p.bill is on a distinguished road
If your float brings a magnet up to a glass enclosed reed switch, then there is no possibility of getting crud on the contacts.
j.p.bill is offline   Reply With Quote
Old 30th May 2007, 12:35 AM   (permalink)
Experienced Member
jbeng is on a distinguished road
Originally Posted by Gaston
why not just use a float with a mechanical switch? it seems like that would be the simplest and most reliable
I designed a detector for my brother last year using a mosfet. It was to monitor the basement sump level in the event the power went out.
One night, it was raining heavily and he heard the alarm downstairs, so he went to check on it. The float for the pump switch had stuck in the down position and the sump was nearly full.
It was $10 well spent (mostly on the case and 9v battery).
Jeff
jbeng is offline   Reply With Quote
Old 30th May 2007, 03:22 AM   (permalink)
Experienced Member
ROLF, .01 inches? You can do better with humidity and temperature sensing in a known enviornment. physical contacts are a good backup, but no reliable enough on their own. Guess it goes to show no matter what the situation there is no single best responce, a mix of all of them are best to cover all ground.
Water Activated Alarm ElectroMaster Electronic Projects 29 21st January 2008 04:15 AM
I want to improve my remote car alarm system. Turbo_Boss Electronic Projects Design/Ideas/Reviews 2 4th January 2007 09:26 PM
submerging a pressure sensor under water? AndyWatson Electronic Projects Design/Ideas/Reviews 14 26th October 2006 09:37 AM
water activated alarm godwin Electronic Projects Design/Ideas/Reviews 2 3rd May 2004 07:26 PM
Increasing the volume level of an alarm over a time period! Shez Electronic Projects Design/Ideas/Reviews 5 4th November 2003 10:13 PM
