Notices
Old 9th March 2007, 05:54 PM   (permalink)
Experienced Member
Gayan Soyza is a glorious beacon of lightGayan Soyza is a glorious beacon of lightGayan Soyza is a glorious beacon of lightGayan Soyza is a glorious beacon of lightGayan Soyza is a glorious beacon of light
Arrow Flashing a LED with Mouse
Don’t throw your old mouse do a fun project with it. This is the simplest project I have ever made. Some may have done a similar like this before but this is my own idea & I want to share the idea with you.
See Pic - 1
This is designed under a PS2 ordinary two button mouse. The cable is replaced by a 3mm blue LED bulb. So when any of the button is been pressed the LED bulb goes ON. That’s it.
By Replacing the LED with an IR bulb, LASER, any other BULB or a SENSOR can make it use in a different way. So it can have plenty names according to your output.
Even you can use as a Morse code.
Circuit
The circuit is very simple as you can see in the fig - 2.The batteries (+) terminal is going through the two switches in the mouse. (The two switches must be connect according to the diagram below. Most mouse switches having 3pins you have to find the common pin & the push on contacting pin. The other copper tracks need to be disconnected.)
It’s leading to the LED’s (+) terminal via the R resistor. You can calculate the value of the R, it’s depending on the supply voltage & the LED voltage. Here I have used a 220ohm resistor to a 9V battery. [(9V- 2.5V) / (30/1000)] = 216.66 ohms.
See Fig – 2
Placing the components.
See Pic - 3
Placing is very simple. The battery is the only bigger part inside. For adequate room for battery the circuit board & the roller balls have to be cut & adjusted. If there is no such a room then you can alter the 9V battery to the AAA sizes as you wish. But make sure to adjust the R.I have replaced the R also inside the circuit board. All the copper tracks which were there in the board I have disconnected. Only taking the switch joints to connect the circuit wires.
The diameter of the mouse wire hole is ideal for 3mm LED bulb. You can attach a LED holder to that cut piece to hold the LED if necessary. And also I have added a battery clip for the 9V battery.
So it takes few minutes to complete this project. You can use this simple circuit for various things.
Try & workout.
Good luck
Gayan
Forum Supporter
Gayan Soyza is offline   Reply With Quote
Old 9th March 2007, 06:21 PM   (permalink)
Experienced Member
Sounds quite a good idea, I suppose you could use a Joul Thief and run it off a single AA cell. The only thing is I've got so many LED torches around I don't need it.
Hero999 is online now   Reply With Quote
Old 19th March 2007, 02:34 PM   (permalink)
MonkeysAteMe is on a distinguished road
This sounds like a great project for a beginner (me).
Out of curiousity if I were to switch the battery terminals, have the negative running to the switches, and then switch the led around, would it still work?
Does it matter that the positive is the polarity running through the switches?
MonkeysAteMe is offline   Reply With Quote
Old 19th March 2007, 09:16 PM   (permalink)
Experienced Member
Andy1845c is just really niceAndy1845c is just really niceAndy1845c is just really nice
Send a message via MSN to Andy1845c Send a message via Skype™ to Andy1845c
As long as you flip the LED too, it will work.
Andy1845c is offline   Reply With Quote
Old 20th March 2007, 12:36 AM   (permalink)
Experienced Member
bananasiong is a glorious beacon of lightbananasiong is a glorious beacon of lightbananasiong is a glorious beacon of lightbananasiong is a glorious beacon of light
A Joul Thief requires more components than this right? But the advantage is the single AA cell
Superman Returns..
http://www.supermanhomepage.com/imag...an-returns.gif
My friend created this account for me.. LOL
http://bananasiong.myminicity.com
oh.. somemore
http://bananasiong.myminicity.com/env
bananasiong is offline   Reply With Quote
Old 20th March 2007, 12:41 AM   (permalink)
Experienced Member
Long time ago I found a circuit that use only a single NPN, a huge capacitor and a LED to do flashing. I think these are the only components, but I've forgotten to save the url as well as the image, couldn't find it anymore.
Has anyone seen this kind of schematic?
Superman Returns..
oh.. somemore
Old 21st March 2007, 01:33 AM   (permalink)
Experienced Member
I found this, accidentally
http://cappels.org/dproj/simplest_LE...r_Circuit.html
Superman Returns..
oh.. somemore
Old 21st March 2007, 02:46 AM   (permalink)
Experienced Member
Hi bananasiong thats also a good circuit.But we have plenty automatic ON/OFF LED's in my place just need to give directly 3V.Also having 5 colour LED's (colour changing ones). Price : 5 SLR that is 0.045 US$.Anyway thanks for sharing.
Gayan
Forum Supporter
Old 21st March 2007, 03:20 AM   (permalink)
Experienced Member
but this is the simplest LED flashing circuit I've ever seen. But I haven't tried it yet.
Superman Returns..
oh.. somemore
Old 21st March 2007, 10:45 AM   (permalink)
Experienced Member
True, but the price of an AA cell plus all the components for a Joul thief still works out cheaper than an expensive 9V battery; it will also last longer too.
Old 21st March 2007, 11:26 PM   (permalink)
Experienced Member
Agree, a 9 V battery is expensive and crappy. Over here, for Energizer, a 9 V rechargeable battery (150 mAh ) is almost the same price as four AA rechargeable batteries (2500 mAh).
Superman Returns..
oh.. somemore
Old 22nd March 2007, 12:50 PM   (permalink)
Experienced Member
It has the advantage of being frequency adjustable and makes a nice buzzer too.
http://www.radiolocman.com/electrica...e.html?di=8055
Old 28th March 2007, 10:53 PM   (permalink)
enahmadbs is on a distinguished road
nice idea >>>>
enahmadbs is offline   Reply With Quote
Request for help on an LED bar graph circuit by an electronics noob. ThrowingChicken Electronic Projects Design/Ideas/Reviews 38 14th April 2007 01:08 AM
LED display segment flashing sequence john1 Electronic Projects Design/Ideas/Reviews 6 30th January 2007 02:06 AM
What is diffrence between machinery mouse and the photoelectricity mouse iamyanh Micro Controllers 2 19th January 2007 01:14 AM
A mouse input design. Please help. bobolified Electronic Projects Design/Ideas/Reviews 5 22nd February 2006 05:46 AM
Using a mouse optical encoder shehry Robotics Chat 5 2nd February 2006 11:15 PM
