| Notices |
| Electronic Projects A collection of small electronic circuits and projects you can build. |
| Experienced Member | I just built a high power H-Bridge for my inverted pendulum project and I thought I would share it. I was running it at 45VDC into a 12 ohm, 200W resistor with no problems (thats over 150W). I was alittle over ambitious with this H-Bridge, it turns out my servo motor for the pendulum draws <50W when running. The motor itself is capable of 200W. There's a few things that need to be noted: 1. High voltage is lethal. attempt at your own risk. 2. This circuit generates alot of electrical noise. Opto-isolation of all logic inputs is definitly recommended. Add additional stiffening/bypass capacitors across all voltage supplies. I'm thinking about making up a PCB for this circuit over winter break. I'll be sure to post it if I do.
__________________ Jeff Zimmerman To the optimist, the glass is half full. To the pessimist, the glass is half empty. To the engineer, the glass is twice as big as it needs to be. |
| Experienced Member | That's a bit over-engineered but there's nothing wrong with that. I wouldn't worry about working with 45V, it's still considered to be a non-lethal ELV (extra low voltage). |
| Experienced Member | No flyback diodes? How do those MOS drivers work? Does the driver activate both high and low sides when IN = HI? Or does IN=HI only activate the high side and IN = LO only activate the low-side? Because if it's the former it would create a short and if it's the latter a PWM = HI would make the motor go forward and PWM=LO would make the motor go backwards and jerk the motor fwd/bwd and PWM rates and damage it? Maybe I just don't know how the driver works. Last edited by dknguyen; 19th December 2006 at 08:04 PM. |
| Experienced Member | I think they're body diodes, because they have the little ticks at the end which make them look like zeners. |
| Experienced Member | Well if my understanding is right, the voltage spike will exceed the supply voltage by the diode's voltage drop plus the amount the spike continues to rise before the reverse recovery time of the diode kicks in, so even if the body diode can still handle the current (which it should easily be able to do since the FET can), if the current being switched is high enough it could still cause the voltage spike to get too high before the diode reacts. |
| Experienced Member | Quote:
When you put in a logic 1, it'll drive the highside fet. So by inverting the input of the second driver, it'll drive the lower fet on the other side. A 50% duty cycle will hold the motor still. The chip also has a built in dead time to prevent shoot-through, which is adjustable on the IR21844's via pin 4. It works very well. Running at 25kHz, I dont think switching directions that fast will cause any damage.
__________________ Jeff Zimmerman To the optimist, the glass is half full. To the pessimist, the glass is half empty. To the engineer, the glass is twice as big as it needs to be. | |
I see. So your control scheme is more of a "complimentary" nature? PWM<50% causes the motor to spin at various speeds in one direction and PWM>50% causes it to spin in the other? That's the locked anti-phase drive right? It reduces the current flowing through the diodes, but current isn't really the problem when you are using body diodes (and at 48V, 200W the current is relatively measly anyways). I dunno...I just don't trust body diodes. Last edited by dknguyen; 20th December 2006 at 04:11 PM. | |
| Banned | Quote:
Normally what he is doing is not a problem and there are FETs designed just for it. D. | |
| New Member | Quote:
FYI, a reverse biased diode across and inductor is also known as a 'free-wheeling' diode because the current is allowed to cycle back into the inductor until the magnetic field collapses. When using PWM this makes the circuit more efficient because it maintains the magnetic field in the coils longer as power cycles on and off. If you put in fast switching diodes rated between 45v and the breakdown voltage of the FET then they will serve as both the zener and the free-wheeling diode. The benefit here, is that the diode heats up during the pwm off cycle instead of letting the FET heat up in both the off and on cycles. | |
| Need some help with a code provided by ATMEL | ikalogic | Micro Controllers | 1 | 23rd January 2007 02:45 PM |
| Need Help on High Current H Bridge | pidot | Robotics Chat | 16 | 15th September 2005 06:46 AM |
| Designing a simplified chopper power supply | HandyMan | Electronic Projects Design/Ideas/Reviews | 11 | 11th September 2004 02:02 PM |
| What is the difference between Va and watts. | goodpickles | General Electronics Chat | 10 | 8th September 2004 09:03 AM |
| High power h-bridge | dreed75 | Robotics Chat | 8 | 23rd August 2004 10:09 PM |
