Old 28th June 2009, 12:03 AM   #121
Originally Posted by kchriste View Post
No, the feedback path is via the 1.18K and 1.2K divider. The transistors, combined with the LM317, try to keep the voltage at the junction of the divider at zero.
They don't try to keep the voltage at zero
It doesn't hold it at 0V but at -Vbe, 700mV nominal.
I haven't simulated yet, I don't have all the models.
Here's a part calculation, part guess of what the voltages and currents should be around the circuit.
if I know the answer.
Hero999 is offline
Old 28th June 2009, 12:22 AM   #122
Hi again,
I made a few changes and yes a regulated reference voltage does help.
Here is the revision that tracks much better...but of course now requires
an additional reference voltage regulator.
(Note i did no temperature studies yet either)
Variable Bipolar Power Supply-plus-minustrackingreg-02.gifMinusTrackingReg-02.gif
MrAl is offline
Old 28th June 2009, 12:27 AM   #123
Why do you need another regulator?
Why not just use the input voltage?
Hero999 is offline
Old 28th June 2009, 01:38 AM   #124
If the base of the PNP was at -700mV, then the NPN would be in full cut-off. The Vbe drops of the two transistors effectively cancel each other out.
kchriste is online now
Old 28th June 2009, 11:18 AM   #125
You're right, I totality missed that.
Well both transistors will have slightly different Vbes which will be made worse as the base currents differ. Another thing is that the lower 2k2 resistor is taking slightly more current than the upper 2k2 resistor.
Using Darlingtons would probably minimise these effects.
EDIT:
Darlingtons won't help because of the saturation voltage.
Here's an idea, it probably isn't as stable as the one with two regulators but it uses less parts. I've also tried to balance the base currents more.
Hero999 is offline
Old 28th June 2009, 03:51 PM   #126
Hi Hero,
I see what you mean there. I guess if the 20v supply is stable enough it
should work. We would have to make sure the ripple is low enough too
probably.
Wouldnt the new value be closer to 7.2k though? I say this to keep the
current the same as when using a 1.6k resistor to 5v. New new resistor
would be 19.3/4.3 times the old resistor. True?
MrAl is offline
Old 28th June 2009, 08:08 PM   #127
Whoops that should have been 33k, 35k2 would be the ideal value but I selected the nearest E12 value.
I think it should allow 1/10th of the collector current.
Having it too low will worsen the tracking because the base current will be higher causing a greater disruption to the potential divider.
Hero999 is offline
Old 28th June 2009, 11:38 PM   #128
Hi again,
Well i found that when the resistor value was too high (5k) it caused worse
tracking, that lead to the 1.6k value as being pretty good for voltages of
5, 10, and 15v outputs. I would change to 7.2k because that is close to the
value i get when i multiply the old resistor by 19.3/4.3, which are the two
voltage drops by that resistor with a source of 20v and a source of 5v.
5v being the old source, and 20v being the new source. The keeps the
current level exactly the same as before switching to 20v.
How did you arrive at a much higher value?
MrAl is offline
Old 29th June 2009, 03:59 AM   #129
According to my sims, the transistor circuit oscillates at high frequency (frequency depends on load current). A 10pF cap from the ADJ pin to the summing node gets rid of it.
Keep in mind this is a simulation.
Ron
Roff is online now
Old 29th June 2009, 11:55 AM   #130
Hi Roff,
Did you include the 1uf cap in your simulations too?
At what level where the oscillations? 1mv, 10mv, 100mv, etc.?
I took a little time to look at the circuit from a temperature point of view, and
i can see that it works quite well indeed, as long as the two transistors are
'matched'. That is, a complementary pair. As long as the two base emitter
voltages track over temperature the circuit stays the same...same output.
The sensitivity is quite low too, about 0.2 or so.
There seems to be quite a tolerance for change of individual transistor
gain change too.
MrAl is offline
Old 29th June 2009, 07:44 PM   #131
Originally Posted by MrAl View Post
Hi Roff,
gain change too.
I missed the 1uF cap. When I added it, the transient load response was basically identical to the LM317 alone. The 10pF cap without the 1Uf is much faster....
Howsomever: Add a 100uF cap from output to GND, and this all seems to become moot.
Ron
Roff is online now
Old 30th June 2009, 05:35 PM   #132
Hi again,
Yes, the 100uf cap from output to ground seems to help. When i add a
little ESR it gets a little worse, but still better.
I was trying to keep some cap where the 1uf was to try to keep ripple
down low.
I guess we would have to move to a real circuit next to see what happens.
MrAl is offline
Old 18th July 2009, 04:16 PM   #133
Just one question: why does this project have the work expert in the title?
I disagree with this, it should be intermediate level at most.
Hero999 is offline
Old 19th July 2009, 01:03 PM   #134
Hi Hero,
I have to agree there :-)
It's just a power supply right?
Maybe because it's a little bit of an advanced power supply.
MrAl is offline
Old 19th July 2009, 04:08 PM   #135
Maybe they are assuming it is designed by an "expert"
This thread is unusual in that the first post is displayed on this page (9) along with Hero999's long row of green squares.
variable power supply tom hewitt General Electronics Chat 2 4th January 2008 08:51 PM
variable voltage power supply mahmoud shendy General Electronics Chat 8 28th December 2007 06:23 PM
Bipolar power supply with digital control GizmoWizard Electronic Projects Design/Ideas/Reviews 11 15th March 2006 02:53 AM
Variable DC Power Supply Night Thrasher Electronic Projects Design/Ideas/Reviews 8 10th January 2006 01:11 PM
variable power supply jimmythefizz Electronic Projects Design/Ideas/Reviews 9 4th October 2004 06:37 PM
