Old 24th June 2009, 11:23 PM   #106
I don't care about the turn-on transient, the fact that it might take a couple of hundred ms to turn on is not a problem.
What do you mean by steady state transient? That sounds meaningless to me.
The problem is the transient response to an increase and decrease in loading isn't as fast as I feel it should be.
if I know the answer.
Hero999 is offline
Old 25th June 2009, 01:38 AM   #107
Hello again,
I meant the transient response after the circuit has had time to reach steady state.
That would be what you were testing for i believe.
What i was wondering now is exactly how good do you want the transient
response to be? That is, how many microseconds before the output gets
back to within 1 percent of the original output?
In other words, say we have a 10v output, then an extra load is switched onto
the output and it causes a dip down to 9v, and it takes 100us to get back
to 9.9v. Is 100us ok or do you need faster?
What i am doing here is trying to get an idea how good you need this circuit to
be. What i was proposing is that you test one LM317 without any extras (just
one 10v output for example) and see if the transient response is good enough
for your purpose. If not, then certainly a dual circuit will not be good enough.
If you let me know what kind of transient response you need i can try a few
different things in order to try to attain that specification, but first i would
myself test the LM317 by itself to see if it can even do it when it is working
all by itself (no extra transistors or controlling op amps).
The transistor replacement circuit is pretty cool, but unfortunately when the
output is adjusted for a different level of 2x the first level the voltages move
apart by as much as 0.1v, which is too much for a tracker. For that one
set voltage though it works pretty nice.
MrAl is offline
Old 25th June 2009, 07:10 PM   #108
To be honest, I haven't thought much about how good I want it to be.
I suppose, even if it's near-perfect i.e. <1µs for the output to be within 5% of the set value at full current, then the inductance of the cables will probably make the transient response worse.
Please post you're circuit, I'm still interested, even if it isn't perfect.
Hero999 is offline
Old 25th June 2009, 07:52 PM   #109
Hi again,
Ok sure, i'll have to draw it up.
MrAl is offline
Old 26th June 2009, 04:35 PM   #110
Here's the circuit...
ADDED:
I almost forgot to mention that the 661 resistor is changed to adjust output voltages,
but some adjustment in the 1.18k resistor is also needed to keep the tracking perfect.
Variable Bipolar Power Supply-plus-minustrackingreg-01.gifMinusTrackingReg-01.gif
MrAl is offline
Old 26th June 2009, 10:22 PM   #111
That's a cleaver little circuit. I can see why it doesn't track perfectly: it's because of the base voltage isnt' it? Perhaps an old germanium transistor might help.
It turns out the transient response isn't that bad after all. The negative is slightly worse, it rings a little bit when the load is disconnected.
Here are some screen shots of the positive supply. For some reason my camera doesn't like photographing the 'scope so sorry about some of the shots being a bit blurred.
Test conditions:
The power supply was set for 13.2V. Two 22R thin film resistors were connected in parallel, these which switched on and off by an IRL540 MOSFET driven from a signal generator. The frequency was varied so I could clearly see the load connect and disconnect transients.
All the waveforms shown below are from the positive side of the supply:
1 & 2 The whole waveform
1) 5µs 200mV
2) 2µs 200mV
The transient occurring when the load is disconnected.
3) 1µs 100mV
Variable Bipolar Power Supply-scope-psu-5u-0.2v.jpg   Variable Bipolar Power Supply-scope-psu-2u-0.2v.jpg   Variable Bipolar Power Supply-scope-psu-1u-0.1v-r.jpg
Hero999 is offline
Old 26th June 2009, 10:25 PM   #112
Positive side of the supply again.
The transient occuring when the load is connected.
1µs 200mV
Hero999 is offline
Old 26th June 2009, 10:37 PM   #113
Here are the waveforms on the negative side of the supply.
1) 10µs 200mV
2) 5µs 200mV
3) 2µs 200mV
I think it's weird how the ringing only occurs when the load is disconnected, maybe a compensation capacitor might help after all.
Variable Bipolar Power Supply-scope-psu-10u-0.2v.jpg   Variable Bipolar Power Supply-scope-psu-5u-0.2v.jpg   Variable Bipolar Power Supply-scope-psu-2u-0.2v.jpg
Hero999 is offline
Old 26th June 2009, 11:07 PM   #114
1 The nasty ringing transient when the load is disconnected.
1) 2µs 100mV
2) A the load connected from the + to the - with it set at 8.25V or ±16.5V for a load current of 1.5A.
Look at how large the turn off transient is 1.7V!
2) 5µs 500mV
3) Picture of test device.
A MOSFET plus thin film resistors were used for this test.
Note the overly thick gauge wire used for minimal inductance. The thin film resistors also have a very low inductance and are rated to 500MHz.
EIDT:
The transient response seems to be better than it was when I tested it previously. The only things I can think of is that this time I've made an effort to minimise the impedance between the load and the PSU and the 'scope was connected directly to the supply terminals rather than across the resistor.
I think I'll test my load connected to a 12V SLA (which should have damn near perfect transient response) as a control.
Variable Bipolar Power Supply-scope-psu-2u-0.1v.jpg   Variable Bipolar Power Supply-scope-psu-5u-0.5v.jpg   Variable Bipolar Power Supply-transient-tester.jpg
Hero999 is offline
Old 27th June 2009, 03:57 AM   #115
Hi again,
Oh yeah, i didnt think about exactly why it doesnt track well yet,
i have only been fooling around with this circuit for a day or two now.
That's a good idea though...try to find out exactly what is causing
the tracking problem and maybe find a way to fix it. It very well
could be the voltage as you are thinking.
So you are saying that the transient response looks ok now?
That's good to hear. Maybe this circuit (with the op amp)
will work out after all which would be very nice.
BTW thanks for the scope shots. It's nice to see what is
actually happening for a change.
MrAl is offline
Old 27th June 2009, 04:35 AM   #116
It could be due to the fact that the NPN is working with a current source and the PNP with a 5K resistor. So the current through the PNP varies as the output voltage is adjusted but the current through the NPN does not. Try tying the top of the 5K resistor to a separate 5V source such as a 78L05 powered from the +20V instead to see what happens.
kchriste is online now
Old 27th June 2009, 02:51 PM   #117
Here's a picture of the test being conducted on a 7Ah 12V SLA with a 1000µF capacitor in parallel.
2µs 20mV
It's still odd how the disconnection and connection transients differ. The connection transient is longer with a lower voltage than the disconnection transient.
I suppose it's dude to the switching characteristics of the MOSFET. Still the transients are much smaller than with the regulator which proves that my little load transient tester is working properly.
Hero999 is offline
Old 27th June 2009, 03:48 PM   #118
Hi again,
kchriste:
But doesnt that 5k resistor have to be connected to the output so it sees
the feedback? I could try it anyway though.
Hero:
That's interesting, maybe there is still some inductance in there some where.
That spike looks like inductive kick back. Some battery models have a small
inductance in series with the rest of the model (capacitors and all). I have
to wonder if it could be that perhaps.
MrAl is offline
Old 27th June 2009, 06:52 PM   #119
kchriste:
No, the feedback path is via the 1.18K and 1.2K divider. The transistors, combined with the LM317, try to keep the voltage at the junction of the divider at zero. Thus when the negative voltage goes lower it reduces the voltage on the base of the PNP and thus also the base voltage of the NPN which causes it's collector voltage to rise. That causes the output of the LM317 to rise until the positive voltage equals the negative voltage output by the LM337. The 5K resistor is simply a bias resistor which supplies base current to the NPN so it can turn on. If you keep the bias current through the 5K resistor constant, the regulators may track better.
Old 27th June 2009, 08:14 PM   #120
Hello again kchriste,
Ok, i havent quite looked at it as thoroughly as you have so i will take your
word for it, and try it a little later today. I'll get back here with the results.
MrAl is offline
variable power supply tom hewitt General Electronics Chat 2 4th January 2008 08:51 PM
variable voltage power supply mahmoud shendy General Electronics Chat 8 28th December 2007 06:23 PM
Bipolar power supply with digital control GizmoWizard Electronic Projects Design/Ideas/Reviews 11 15th March 2006 02:53 AM
Variable DC Power Supply Night Thrasher Electronic Projects Design/Ideas/Reviews 8 10th January 2006 01:11 PM
variable power supply jimmythefizz Electronic Projects Design/Ideas/Reviews 9 4th October 2004 06:37 PM
