| | #46 |
No I haven't. I reasoned that it probably wouln't help because the positive line is just as bad as the negitive. I don't know how I can improve it anymore. I've tried adding 100nf to the output it it didn't get much better to I increased this to 1µf without seeing a significant improvement. I suppose I might be able make the internal leads connecting the PCB to the output shorter and thicker to reduce their inductance and skin effect but I don't know what else can be done.
| | #47 |
I haven't read "Spice uncovers regulator-stability problems" carefully, but I have seen ringing on LM317 sims. I have not made hardware comparisons to verify the sim results. I thought you might find this interesting.
| | #48 | ||
But if you see ringing on the simulator...!?! | |||
| | #49 | |
| | #50 |
The datasheet says the LM317 will current limit between 1.5A and 3.4A with 2.2A being typical so I suppose I have a pretty average LM317. It seems silly that the spice models say it's more stable than it is. I would make it the other way round so when engineers actually use it they know it'll work when the simulation says it will. I'll try using a 4.7nf capacitor on the adj pin and it the, then I'll see what I can do about the negitive supply.
| | #51 |
Anyway the LM317 wouldn't be a problem without the op-amp. You have to see if an RC network can be found to shape the loop gain (you need a zero!). If you take my advice, you may try to re-design the PSU with two op-amps and a voltage reference. I gave this direction to my ideas and I'm designing the circuit. But I need a new transformer and it will take some time. ______ See also AN-1148 (National): nice app note about linear regulators. Last edited by eng1; 7th November 2006 at 03:39 PM. | |
| | #52 | ||
| | #53 | |
This is a valid method and ensures good tracking. | ||
| | #54 |
In my opinion there are two l.f. poles: the first is set by the internal compensation (Cc); the second is from the op-amp. The loop gain should roll off with -40 dB/decade slope in the mid freq. range. Unfortunately I can't simulate the circuit.
| | #55 | |
What you are forgetting is that if there are two low frequency poles there is double the phase shift, therefore 180 degrees will occur well before the op-amp reaches unity gain causing oscillation.
__________________ I do not answer private messages asking for help because no one else can: benefit from advice I may give or correct me if I'm wrong. Please ask on the open forum if you have a question and I'll be happy to help, if I know the answer. | ||
| | #56 | ||
| | #57 |
The transient response it just as poor on the positive supply as the negitive, even though it isn't using an op-amp.
| | #58 | |
| | #59 |
Hi, As Ron H pointed out you really should add those input capacitors, last year I was working in the tech department of a medical device company here in Brazil, and we were having similar problems with a power supply that used 7805, and adding those small tantalum caps, (before and after) the regulators really helped with the ripple figures, here is a quote from the application notes on the datasheet from national: “An input bypass capacitor is recommended. A 0.1µF disc or 1µF solid tantalum on the input is suitable input bypassing for almost all applications. The device is more sensitive to the absence of input bypassing when adjustment or output capacitors are used but the above values will eliminate the possibility of problems.” What type of capacitor did you use for the adjustment pin bypass? Can you measure the ripple frequency at the output? This is my first post here, hope i could help, and sorry for any grammar mistakes, English is not my native language.
__________________ Felipe Madi. Last edited by FMadi; 10th November 2006 at 03:52 PM. | |
| | #60 | |
| variable power supply | tom hewitt | General Electronics Chat | 2 | 4th January 2008 08:51 PM |
| variable voltage power supply | mahmoud shendy | General Electronics Chat | 8 | 28th December 2007 06:23 PM |
| Bipolar power supply with digital control | GizmoWizard | Electronic Projects Design/Ideas/Reviews | 11 | 15th March 2006 02:53 AM |
| Variable DC Power Supply | Night Thrasher | Electronic Projects Design/Ideas/Reviews | 8 | 10th January 2006 01:11 PM |
| variable power supply | jimmythefizz | Electronic Projects Design/Ideas/Reviews | 9 | 4th October 2004 06:37 PM |
