| | #31 | |
We're used to see two resistors (R2, R1) that form a feed-back network and set the output voltage. If we don't use the standard configuration and we add an op amp the circuit is more complicated, especially as far as the loop gain is concerned. Last edited by eng1; 23rd October 2006 at 10:26 PM. | ||
| | #32 | |
| | #33 |
Adjustable Symmetrical Power Supply
| | #34 |
My computer wants me to guess what version of Word (or whatever) you used. At 162 bytes, I can't imagine it is a schematic. Is it? How about posting it as a GIF or PNG?
| | #35 | |
These equals voltages (with opposite polarities) are connected to the adj pins. Resistors between output and adj pin of each regulator are still necessary (you made me aware of this some time ago) but they don't set the Vadj; they only set a minimum load current for the regulators (1.25/R). The op amps are used in a closed loop configuration. If they add a pole, it is beyond the unity gain frequency of the regulators and doesn't affect stability. The LF411/2 have low offset, low drift, high bandwith, high output current. The positive output can track the negative one with good precision in my opinion. The error is mainly the mismatch between the internal references of the regulators, but this could be be easily eliminated because it is constant. | ||
| | #36 | |
| | #37 |
Most of the dual pots I've seen have tracking specs around 20%. I've never actually tried to build supplies with them, but I do have an op amp version. I have an old plugboard which had built-in +5, +15, and -15 volt supplies. I modified the ±15 supplies by changing the trimpot on one to a pot with a knob on it, then added the op amp to make them track. A dual pot costs more than an op amp, the op amp version has better tracking with good stability. Last edited by Roff; 24th October 2006 at 04:57 PM. | |
| | #38 | |
I've tried simulating this myself. I didn't have a model for the LM317 so I've made one using a uA741 with a few other componants and it works. However Ron's model will be far more acurate than mine so I accept his results over mine. The only thing I can think of is I'm probably wrong. Maybe the LM317 acts as an open loop gain stage which is sure to cause oscillation. Perhapps the uA741 is over- compensated to such a high degree that it cancels this effect out so my circuit works as does my simulation.
__________________ I do not answer private messages asking for help because no one else can: benefit from advice I may give or correct me if I'm wrong. Please ask on the open forum if you have a question and I'll be happy to help, if I know the answer. | ||
| | #39 |
Here's the simulation of my model of the LM317. Is is acurate enough for this? The only thing that's missing is the current and thermal overload protection circuits. I couldn't upload this for some reason so I've uploaded it somewhere else.
| | #40 | |
Try a pulsed current sink for the load. I ran basically this same sim. See below. First waveform, Ccomp=0. Second waveform, Ccomp=100nF. | ||
| | #41 |
The LM317 has a high gain compensated opamp inside. The compensation causes 90 degrees of phase shift. If it is in the negative feedback loop of a similar opamp like a 741 then the phase shift adds to 180 degrees at high frequencies and the combination will oscillate.
| | #42 | ||
It5 still works according to the simulation, there's some spikes when the switch turns off and dips when it turns on but there isn't any ringing. Anyway I don't trust simulators. I've brought it home from work now and I'll test it properly tomorrow.
__________________ I do not answer private messages asking for help because no one else can: benefit from advice I may give or correct me if I'm wrong. Please ask on the open forum if you have a question and I'll be happy to help, if I know the answer. | |||
| | #43 |
I just got round to testing it when I turned the scope on, it made a buzzing sound, a gree line appeared on the screen briefly then it stopped working. I'll start a new thread about this .
| | #44 |
Well I still haven't got round to looking at the scope but I took my power supply into work and tested using a scope that works. I couldn't see any oscillation on either the -V or +V supply but both behaved pretty poorly under transient conditions. I connected a MOSFET to a 12 hm: resistor on the output and drove the gate with a 50kHz waveform. I treid to make the leads as short as possible but there was significant ringing on the output when the load was turned on and a big glitch when it turned on. I would say that the noise at worst was about 1Vp-p. I performed this test on both the positive and negitive lines and got similar results, as expected noise on the +V line gets transferred to the -V line but not the other way round.I was impressed with the current output though, I managed to set the supply upto +-12V with 12 hm: connected from + to - and the output didn't drop at all. 2A isn't bad at all for a pair of regulators only rated for 1.5A.
| | #45 |
So did you try adding some compensation? It might get rid of the overshoot and ringing.
| variable power supply | tom hewitt | General Electronics Chat | 2 | 4th January 2008 08:51 PM |
| variable voltage power supply | mahmoud shendy | General Electronics Chat | 8 | 28th December 2007 06:23 PM |
| Bipolar power supply with digital control | GizmoWizard | Electronic Projects Design/Ideas/Reviews | 11 | 15th March 2006 02:53 AM |
| Variable DC Power Supply | Night Thrasher | Electronic Projects Design/Ideas/Reviews | 8 | 10th January 2006 01:11 PM |
| variable power supply | jimmythefizz | Electronic Projects Design/Ideas/Reviews | 9 | 4th October 2004 06:37 PM |
