Old 15th August 2009, 10:30 PM   #76
For PCB design I use this software:
TARGET 3001! V14 PCB-POOLŽEdition
http://www.pcb-pool.com/ppuk/service_downloads.html
This software is excellent, best of all it is legally FREE! You can design circuits and view the pcb in 3D. Unlimited pins/unlimited size. It allows you to print the pcb. The only limitation is you can not export mechanical milling and drilling formats/information.
I use this etchant:
Stop using Ferric Chloride etchant! (A better etching solution.)
I use this paper:
Staples "Picture" paper
I use my laser print to print the pcb design on the glossy side of the paper. Next, I use a clothes iron to transfer the toner to the pcb copper clad. Finally, I soak the pcb in water to loosen up the paper and rub/peel it off until all that remains is the toner. Once the pcb is etched acetone can be used to remove the toner.
Also check out:
Easy PCB (Printed Circuit Board) Fabrication, Using Laser Printer Toner Transfer, with a Household Clothes Iron and Glossy Inkjet Photo Paper; DIY at Home; Better AND Cheaper than Press-n-Peel ( PnP / P-n-P )! Making, Cheap , Economical , fastest fas
3dOptics is offline
cheap, etching, good, pcb, solution
