| | #46 |
Can i used the one that is used as wound disinfectant?
__________________ to err is human, to really mess things up, use a computer! | |
| | #47 | |
I know this is a reply to a rather old post. Instead of laser labels I use 3M blue painters tape. It is less gooey. Pulsar transfer paper is very good but it may be hard to find outside the US. It has a starch coating that disolves in water. If your laser printer can print it, it will end up on the PCB. Neat stuff. Quote:
__________________ Please post questions to the forums. PM's are for personal communication. BCHS/3v0's Tutorials Junebug USB PIC programmer kit., USB Bit Whacker, The 15 Minute Printed Circuit Board! (+drill time) | ||
| | #48 |
| | #49 |
Peroxide is the 'common' name, it is a a bleach for hair and an antiseptic. It comes in different strengths, and loses strength whilst stored. The 'strength' can be measured by the volume of oxygen which is liberated from a given volume of Peroxide on an organic matter sample. Why are we asking this ? | |
| | #50 |
| | #51 | |
If I lived in a country where Pulsar did not have a distributor I would give them a call and see if it was possible to setup a distributorship.
| | #52 |
That USB bit wacker looks great ! Is the xtal only for the USB ? ie the PIC can still run at 32mHz ?
| | #53 | |
I think the USB and processor can run from the same clock source. But but you can decouple them to go into a low power mode where the processor slows down but the USB is still active. A quick look at the datasheet. Quote:
| | #54 |
Thanks for the info 3v0, when I get time I'll take a closer look. I need to migrate to USB........
| | #55 | |
To make the mixing safer, youy should pour the the mixture through the wall of the container, sliding the liquid slowly through the wall. Thats the usual practice that we do in chem 1. Just an idea. Thanks! | ||
| | #56 |
That is awesome!
| | #57 |
That is what I do most of the time to save on blue.
| | #58 |
I could never get the H2O2 + HCL mix working, but Copper Oxide + HCL has worked Like a Charm For me. I just use a air bubbler from ebay to help it go a bit quicker and its worked pretty well over the years. Ive been using the same etching solution for quite some time now. The only problem is that my HCL is from the dollar store (toilet cleaner, 10% HCL) and bubbles, so I have to do it in the shower. Still, for $1 I cant beat it (but the copper oxide is a different story-I have to make it from copper carbonate-which I got through a pottery store)
__________________ I believe that you're wrong. Insinuating that they hold the bomb. --- | |
| | #59 |
I've heard (or read) from some people that standing up the board vertically in an etch tank versus laying it down flat makes it go quicker? Just a myth or reality? I could understand that when the board is vertical, maybe the dissolved copper would 'sink' to the bottom keeping the etchant more pure around the PCB. I suppose a bubbler would just fix this problem though? And also, I just have a question about waste disposal of muriatic acid and H2O2. I'm pretty sure that if it's toxic to breathe, it definately is not safe for a septic tank. Any suggestions? I do have access to my Chemistry lab at my University, so maybe I could bring the stuff there, since they usually have a ton of inorganic waste. Don't know how happy they would be though lol! Mike | |
| | #60 | |
i wanted to know if i get you correctly: we can use a common magazine paper to get our ckt from the printer to the PCB board?I ask this because TTP is not available in my city easily.
__________________ Syed | ||
| cheap, etching, good, pcb, solution |
