| | #16 |
simple but yet effective! you just saved my ass man. my medical officer and our janitor to include my commanding officer said how the hell did i etch the circuit without the procured solution?! thanks.... | |
| | #17 | |
| | #18 |
When diluting acid, the rule is "do as ya outa, add acid to water". An even simpler way to remember is to think how hard it would be to add swimming pool water to 5 liters of acid. BTW, this doesn't really matter with HCl but with H2SO4 it's a different matter, add water to conc sulphuric = steam explosion and you get to wear the acid. Also, if the CuCl method works then the first time you use HCl + H2O2 the end product is CuCl. Isn't it? Mike. | |
| | #19 |
After thinking about it, I'm very dubious about the copper chloride method. If the method worked then the HCl + H2O2 method would keep working as the spent solution contains CuCl2 which should get consumed to produce CuCl which is insoluble (1.5g/Ltr). People who have tried this report a green spent liquid which suggests CuCl2 does not react any further. Mike. | |
| | #20 |
| http://members.optusnet.com.au/~esey...uCl/index.html That site has about all the information I think you'd need on the process. I also came across a PDF file that was some sort of information sheet about this process which is used in industry. I'm not an expert on the subject, but he does mention other factors in the process that would affect the etching ability of the Cupric chloride etchant, perhaps there's something else going on that's keeping it from working.
__________________ EEgeek.net Last edited by evandude; 23rd October 2006 at 04:55 AM. | |
| | #22 |
I use laser mailing labels to stick my toner transfer sheet to a larger sheet of paper.
| | #23 | |
__________________ EEgeek.net | ||
| | #24 | |
Originally Posted by bobledoux I use laser mailing labels to stick my toner transfer sheet to a larger sheet of paper. Quote:
| | #25 |
if anyone has any interest i did some molar calculating with this cemical reaction: http://rellermaa.pri.ee/HCl+Cu/HCl+Cu.html (takes some time to load all the eqasions) dodn't want to convert all of that to latex either... i was trying to get the amunt of copper i can ech with 1kg of HCl. maybe in some time i'll make this amount in kg into amound in m^2. PS the mw file ontop of the page is a maple worksheet if someone has maple
__________________ Need Help? Press F1 If that doesn\'t help you, ask me... I might know better. | |
| | #26 | |
__________________ EEgeek.net Last edited by evandude; 23rd October 2006 at 06:08 PM. | ||
| | #27 |
There was a guy on eBay awhile back selling like 10 lb and up bottles of solid Ferric Chloride lumps. Easy enough to turn that into etchant. At first I thought a pound of that stuff would make a lot of etchant. However, I did some calculations and saw that the ferric chloride is actually a very substantial part of the etchant's weight. It was still significantly less $ than buying etchant, but not a miniscule fraction of the cost. One of the transfer sheet companies has been advocating dumping the etchant tank entirely in favor of applying the ferric chloride etchant with a sponge (while wearing gloves), literally rubbing it on. They say this etches a board far, far faster and in the end uses less etchant.
| | #28 | ||
I will attest to the sponge method. A friend of mine etched a board at work with ferric chloride (I don't use it much myself, in favor of ammonium persulfate) and used a wadded up paper towel as a sponge, and the board did etch quickly and evenly, since you can see the progress and focus on areas that are etching more slowly. And of course, it doesn't require much etchant, which is very convenient if you prefer to just mix/pour out a batch of etchant, use it once, and then dispose of it, (instead of having a large tank of etchant that you keep filled constantly) since you will only be going through a small amount at a time that way. According to the CuCl etching page mentioned previously: Quote:
__________________ EEgeek.net Last edited by evandude; 23rd October 2006 at 09:01 PM. | |||
| | #29 |
Bobledeux: I have a question about the pulsar etching system. Does it work that great? I have some of the paper, and I can't get the toner to transfer for crap! I've tried a dozen different copiers, and I've tried a clothes iron, and two differents heat laminators. Suggestions? | |
| | #30 |
A good way to remember this is use the alphabet...A to W not W to A... The explanation is simple..if you have a high concetration Acid (let's say sulphuric acid 10 mole) which would eat through any type of metal, if you would slowly dump the acid into water, the reaction can be controlled by the pouring of the acid into the water. Let's say you dump the water into acid, then you would have a little bit of water reacting with a large amount of acid as the pouring process starts. This is very dangerous because of the large amount of concentration of acid is going to react with every molecule of the water, giving off much heat. I am no scientist but this was 8th grade bio-chem, which is basic reaction control. Use this rule for adding acid into pretty much anything, espcially water. -Jim | |
| cheap, etching, good, pcb, solution |
