Notices
Old 3rd August 2006, 12:46 AM   (permalink)
Experienced Member
Rolf is on a distinguished road
Send a message via Skype™ to Rolf
Default Digital slave flash trigger
This unique circuit has been tried with all three of my cameras and two others and works perfectly. It ignores all pre-flashes and only triggers on the last (main) flash.
No adjustments are needed. It will be tested with more cameras as they become available.
The current drawn is just 2.2mA at 3v. (about 4.2mA at 6v)The AA batteries were only used for making and testing the prototype. The finished unit will use a coin cell. The unit will handle trigger voltages up to 400v. Which I think will handle most commercial strobe units.
The range with 3v is about 25', I am going to work on that. That was much better when I used a 6v battery. There is now a ON / OFF sw. But the blinking LED (shown only in the picture) has been removed, drew to much current.
The hot-shoe was from an old camera I got in a junk store for $ 1.00.
This design is now outdated because of this: http://www.pbase.com/sinoline/pic_slave_flash
Rolf is offline   Reply With Quote
Old 11th September 2006, 11:15 AM   (permalink)
jatinder singh is on a distinguished road
can any bodt tell mewhat it is ?
jatinder singh is offline   Reply With Quote
Old 11th September 2006, 11:16 AM   (permalink)
can any body tell mr what it is?
Old 11th September 2006, 11:52 AM   (permalink)
Experienced Member
This Digital Slave Flash Trigger allows a regular flash to be used with a PS (point & shoot) digital camera.
For a simpler one, see: http://www.pbase.com/sinoline/pic_ii
For more info just do a little Googeling.
Old 11th September 2006, 08:45 PM   (permalink)
Experienced Member
Wow, what a moron?
Anyway Rolf, how did you get your project to work from 3V when the datasheet for the NE556 specifies a minimum of 4.5V?
That 3V battery wouldn't last long?
Or did you use a CMOS timer like the 7556 or TS556?
Old 11th September 2006, 09:46 PM   (permalink)
Experienced Member
Originally Posted by Hero999
Wow, what a moron?
The sensitivity was much better with 6v. When I am experimenting I don't even think about data sheets. Mine is marked NE556N the 4011 is unmarked.
Took the LED out (it was ok when using 4xaaa's for power) and the circuit now draws 2.2mA. The button battery is 180mAH so there is plenty of longevity if you can remember to turn it off.
Old 12th September 2006, 01:06 AM   (permalink)
Experienced Member
audioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to behold
There are reasons that manufacturers spec an absolute minimum supply voltage of 4.5V for a 555 and 556 IC. You might be lucky to find one that works with only 3V. Does it still work when the battery discharges to 2.999V?
If you make another one then I bet it won't work with only 3V.
Old 12th September 2006, 01:57 AM   (permalink)
Experienced Member
How much are you willing to bet?
The one pictured in my original post is actually the second unit I buildt.
If you are so interested to prove me wrong, buid one for yourself. I have put this project on the shelf and are not going to resorect it, just to prove a point. I have now built and use Povel Janko's PIC design (jankop@volny.cz) which made mine obsolete.
Old 12th September 2006, 02:04 AM   (permalink)
Experienced Member
I use Cmos 555's for low voltage and low current stuff. That's what they are designed for.
Old 12th September 2006, 02:16 AM   (permalink)
Experienced Member
GOODY FOR YOU!
Old 20th September 2006, 10:41 AM   (permalink)
Cool_buddy_57 has a little shameless behaviour in the past
Send a message via AIM to Cool_buddy_57 Send a message via Yahoo to Cool_buddy_57
What is this
and how it works..?
Cool Jasim
Cool_buddy_57 is offline   Reply With Quote
