Old 3rd June 2006, 11:07 AM   #1
Default PWM controller
This is a PWM controller design that I have built and which works. As shown, it should function that an increasing voltage applied to the comparator gives an increasing duty cycle at the output, this is variable fully from 0-100%. Swap the inputs on the comparator to give negative correlation if this is desired.
The design uses op-amps to generate a triangle wave which can run at either 120hz or 3khz, this is fed into a comparator input and the reference voltage sets the pulse width. The output of this goes to what is essentially a discrete NOT gate, which is used as the driver for the power MOSFET. I have included control by either a simple control knob, or by an external voltage source. The power MOSFET is heatsinked to the casing which is extruded aluminium (which should make the case live, but when I checked that, it didn't seem to be, mabye the coating is insulating). Tests show it to work quite well, I had to add protection diodes very quickly, even for use with a coiled heater, but thats sorted now. Its all pretty small in its 103x120x30mm case, and should be good for around 10A, tested to 6A with no problems, didn't even get warm.
PWM controller-unit-front-labelled-small.jpg   PWM controller-unit-rear-labelled-small.jpg   PWM controller-low-current-board-small.jpg   PWM controller-controller-end-small.jpg   PWM controller-connector-end-small.jpg
Angry!? I'm absolutely electrolytic!
Music web page:
http://www.music-playground.net/artist/drem/
Dr.EM is offline
Old 26th June 2006, 10:07 PM   #2
I'm currently looking at PWM controller circuits because I need to design a DC-DC converter which I've never done as part of a home project before. I'll take a look at your circuit - thanks
Bri
ThermalRunaway is offline
Old 27th June 2006, 05:55 AM   #3
A corstuit like this is no use for a switching power suply.Go loock at ICs for this job they normaly do the "hard work" or generatng the PWM signal for smaller ones even the switching is intergrated
Il give you shocking experience.
Someone Electro is offline
Old 27th June 2006, 06:59 AM   #4
Yes it was PWM ICs that I've been looking at, and it's probably the better idea, but Dr.EM's circuit is good from an Electronics Interest point of view, and there's no reason to believe that it'd be no good. I think I'll experiment with it.
Brian
Old 27th June 2006, 08:57 AM   #5
It's a speed controller, NOT a switch-mode PSU!.
Old 27th June 2006, 01:03 PM   #6
That's right, this PWM is just useful for controlling motor speed, lamp brightness, heater output or driving transformers. If you need a circuit to do any of those, then this should work fine up to around 6A. I might try it with a 20A 12V motor I have, but the inductance might be a bit leathal for its fairly simple diode protection (which i've just noticed isn't shown there. You must add diodes for use with anything other than lamps which have inherently have very low inductance, non coiled heaters are also ok).
Music web page:
Dr.EM is offline
Old 27th June 2006, 03:29 PM   #7
A fast diode amtiparallel whith the load should make it drive inductive loads no problem.
Old 27th June 2006, 05:12 PM   #8
Ok, I can understand that you use the circuit to control motor speeds and that my application is completely different, but surely the PWM controller part is common? In a DC-DC converter which is designed around a PWM controller IC, the pulse-width is altered by a voltage range at the feedback pin on the IC itself. This feedback voltage is varied by changes in output load, and therefore the pulse-width is changed to compensate for this effect. From reading your description, it seems that those properties fit your PWM controller quite well? What I'm saying is, surely your PWM controller circuit could be adapted to my application?
Or am I missing something completely here...
Brian
Old 28th June 2006, 09:46 AM   #9
Esayest way to make a switchmode powersuply is to buy a SMPS controler IC this can be a very small IC like SOT 5 or up to 28 pins.Then you need a external trasnsistor and the proper cirucit around it.All datasheets containg multiple cirucits that use the chip.
Old 28th June 2006, 03:42 PM   #10
This is fine for lamps and LEDs but if you want to controll motors you need a higher frequency and a diode in reverse paralell with the motor.
if I know the answer.
Hero999 is offline
Old 28th June 2006, 05:22 PM   #11
Hi Someone Electro, I completely agree that it's the easiest way, infact I've already chosen a PWM IC that I was going to use for the project, but because the projects I do are home projects for my own use, the design is not governed by cost, size limitations or even the easiest solution. More often, the way I design a project is governed by how I feel I'll learn the most. This circuit seemed to offer me an opportunity to experiment with PWM controllers at the discrete component level, which I felt I would learn much more from.
I think I'll still go down the road of using a PWM IC now because I've managed to get my prototype working and it seems to be performing quite well, but I think I'll experiment with that circuit!
Brian
Old 28th June 2006, 06:26 PM   #12
In all of my project i try to to it the easyest way posible wich is also mostly the cheapest and easyest to get working.Also less complicated means less thing can go worng.
For instane im curetly making a audio amp for two 20W speakers.Im usinf the TDA 1554 it needs next to no extrenal compomemts and has safety fetures.To make it out of transistors i would need a lot of them and the cost would be much higher.It may also not sound as nice.For the filter i was trying out in the simulator im using the cheap LM741 and i made a "ground" whith a resistor divider circuit to make a single suply op amp unnessery.Becuse i have no dual suply since the amp needs only single suply
Old 28th June 2006, 07:57 PM   #13
I think you can design H-bridge circuit to control motor speed by PWM. I have just designed this circuit since monday.
my circuit was used in robo contest .(do you know this contest)
In my circuit , i am also use MOSFET ,such as IRF540 .
it works very well.
E-DESIGN prestigious and quality
http://pg.photos.yahoo.com/ph/giaosu...765scd&.src=ph
contact me:giaosucan2000@yahoo.com
giaosucan is offline
Old 28th June 2006, 08:08 PM   #14
Yea this circuit only drives curent one way so it cant reverse a motor.
the IRF3205 are good if you want a big motor driver.They have a chanel resistance of 0,008 Ohm when saturated and thats the same as if there was a wire.They are $2,50 bucks each here.But have a prety low voltage of 55V
They can run a 10 Amp motor whith no heatsink,but its recomended.Also need a very good gate driver to run as cool.
Old 29th June 2006, 12:07 PM   #15
Yep, the MOSFETs I used had 0.022ohm ON resistance, so the IRF3205 you mentioned are a better choice (depending on saturation voltage at the gate). Use the lowest Rds ON mosfets you can find for using this circuit. I think i'm going to have to try this with a 20A motor I have, though my diodes aren't extra fast.
Music web page:
Dr.EM is offline
RGB Controller erosennin Electronic Projects Design/Ideas/Reviews 4 10th March 2008 07:53 AM
using a PC as a controller? omnyx Electronic Projects Design/Ideas/Reviews 3 13th July 2007 12:03 AM
Need Help on DC controller 2K3vq General Electronics Chat 2 22nd April 2006 03:51 AM
sms controller gjy808 Electronic Projects Design/Ideas/Reviews 2 28th July 2004 11:08 AM
Light Controller or rather Electrical Outlet Controller mammanoti Electronic Projects Design/Ideas/Reviews 1 11th January 2003 04:09 AM
