| | #61 | |
The post you replied to is a year old!. | ||
| | #62 |
It wasn't me that bumped the thread.
| | #63 | |
| | #64 |
Hi i am new member to forum. i want a diagram of 1000watt sinewave or modified sinewave invertor. i have a little hand on electronics so please send schemetics which are easy to build and understanf thanks for help | |
| | #65 |
I'm currently looking at PWM controller circuits because I need to design a DC-DC converter which I've never done as part of a home project before
| | #66 |
Hi i am new member to forum. i want a diagram of stepper motor speed controler. i have a little hand on electronics so please send schemetics which are easy to build and understanf thanks for help | |
| | #67 |
Hi Dr.EM, I hope not to upset you with my share. I've used your circuit, added a temperature measuring circuit to it and made a PCB of the circuit. It might be useful for cooling purposes. The LM35 has a voltage increase of 100mV/degC and starts at zero volts at 20degC. The non-inverting amplifier might be set to any starting value. The max amplification factor is 26:1 The PCB size is 2.51X1.78" and it's purely single sided, except for a small cheat, where I added a zero Ω resistor instead of a jump. Kind regards Hans P.S. The board is made using Eagle version 3.55. It can be used in version 4.16. For higher versions than 4.16 it must pass through 4.16 first. Everybody interested in the schematic and layout might PM me. I'll send the files right away.
| | #68 |
... and here are the files.
| | #69 |
Hello, Does anyone have a schematic for a PWM dc motor controller with 500W power consumption. I want a simple one with a timer and a mosfet, and if it has an convertig circuit from 220 VAC to 24 VDC is great, but mainly i want the PWM circuit with a mosfet that can deliver 500W. Thank you. | |
| | #70 | |
You are generally better off with an actual regulator chip when you talk about higher power, like the Digi-Key - 497-6139-1-ND (STMicroelectronics - UC3842BD1013TR) for $1.12 instead of a Digi-Key - LM555CMFS-ND (Fairchild Semiconductor - LM555CM) for $0.44 | ||
| | #71 |
Good Circuit DR. EM Thanks
| | #72 |
Beautifull scheme, i can use thanks.. | |
| | #73 |
Hello,i am interested in your design and i want to apply it in a power inverter system up 1500w pls direct me on application.
| | #74 |
We've gone over this more than once in the last few weeks. Don't build one, buy one, if you don't have enough money to buy one from a commercial supplier, just burn all the money you have, cause you'll do no better making it yourself without know exactly what you're doing.
| RGB Controller | erosennin | Electronic Projects Design/Ideas/Reviews | 4 | 10th March 2008 07:53 AM |
| using a PC as a controller? | omnyx | Electronic Projects Design/Ideas/Reviews | 3 | 13th July 2007 12:03 AM |
| Need Help on DC controller | 2K3vq | General Electronics Chat | 2 | 22nd April 2006 03:51 AM |
| sms controller | gjy808 | Electronic Projects Design/Ideas/Reviews | 2 | 28th July 2004 11:08 AM |
| Light Controller or rather Electrical Outlet Controller | mammanoti | Electronic Projects Design/Ideas/Reviews | 1 | 11th January 2003 04:09 AM |
