Old 30th August 2006, 06:37 AM   #31
Default 2 Simple PWM
Try this simpliest PWM
muki55 is offline
Old 8th September 2006, 01:23 PM   #32
Default Hello
Hello the circuits seems good to for study. I would like to know the specifications of Q2, the power MOS and the diode to be place across the load.
Thanks in advance.
svdv is offline
Old 8th September 2006, 01:52 PM   #33
The spec's must match your load's requirements and the switching frequency.
You can lookup the spec's in Google or at www.datasheetarchive.com like everyone else does.
audioguru is offline
Old 1st December 2006, 04:57 PM   #34
Won't your beer can freeze to your mouth?
Old 8th December 2006, 06:59 PM   #35
hi, everybody........
i need some help here.......
i am using power window motor for my project.....
Now i am searching a suitable motor driver in IC package for the power window motor.....
As i know, the L293B is not suitable because it only support up to 1A per channel.......
So, do u all have any suggestion of the motor driver for the power window motor???
AirWalker83 is offline
Old 8th December 2006, 08:21 PM   #36
Your choice is simple: drive a mosfet and live in peace, or pursue your present course and your ic's face obliteration. We shall be waiting for your answer. The decision rests with you.
2.4Gigglehurtz
chiba is offline
Old 9th December 2006, 08:36 AM   #37
Mosfet need to build the circuit?
Cause i still a beginner, not quite understand the MOSFET.
Beside MOSFET, got any other motor driver IC that can replace L293D?
Old 9th December 2006, 10:47 AM   #38
Do you like Salsa? because trying to drive a Window winder that could draw anywhere from 5-30A is going to bake all your chips. However, using a simple low cost ic to drive one of them awfull mosfet thingys will work out cheaper and easier. I'm sure PWM ic's that can handle 30A are available in the future but first we have to get that time line thing sorted.
2.4Gigglehurtz
chiba is offline
Old 9th December 2006, 11:24 AM   #39
No, not that I know of anyway. I recommend that you should do some Googling and research about MOSFETs, they're not that complex, they're basically electronic switchs.
if I know the answer.
Hero999 is offline
Old 19th December 2006, 06:33 AM   #40
all, thanks for the info. lurked for month's now and learned a lot of things.
i plan to build H bridge for wheelchair motor and IRF3205 looks very suitable. at least on paper looks like significant improvement over ifrz44n (and not much more expensive) i thought using first.
Originally Posted by Someone Electro
Also need a very good gate driver to run as cool.
any recomendations for a VERY good one ? HIP4081??
tankist80 is offline
Old 22nd December 2006, 05:04 AM   #41
hi everybody.......
I had saw the datasheet of L298N which the current limit can be raised up by parellel the 2 H-Bridge in the IC. Actually it raised up to how many ampere?
i hear that u all sugest to use power MOSFET, but i actually still dun understand how it can become motor driver???can somebody help?
Or is ther any motor in the market have the same torque as power window motor but will draw less current?
thanks...........
Old 22nd December 2006, 03:17 PM   #42
A Mosfet can switch many amps of current without much waste (heating).
The IRF3205 mentioned can conduct 30A and heat only 7.2W.
If you reduce the current for a motor then its torque becomes less.
A gearbox allows a low-current motor to have more torque but its action is slower.
Old 22nd December 2006, 03:38 PM   #43
thanks for your explaination. Then u have any circuit uisng IRF3205 to build dc motor driver???
Old 22nd December 2006, 03:48 PM   #44
Take any of the thousands of readily available mosfet motor driver circuits and just replace the FET used with an IRF3205 (makeing sure the drive voltages are still acceptable)
straight answer, har har."
Sceadwian is offline
Old 28th January 2007, 06:31 PM   #45
hi, i just buy a motor driver kit for my power window motor.
It can suipport up to 10A. I think it got 2 relays in the circuit.
i had sucessfull testing for the motor to run.
But for the PWM speed control, i didn't manage to do it.
At the spec, it say it can be used for speed control.
is it that is different way for PWM control using relay?
So, did anyboy have any idea regarding this problem?
RGB Controller erosennin Electronic Projects Design/Ideas/Reviews 4 10th March 2008 07:53 AM
using a PC as a controller? omnyx Electronic Projects Design/Ideas/Reviews 3 13th July 2007 12:03 AM
Need Help on DC controller 2K3vq General Electronics Chat 2 22nd April 2006 03:51 AM
sms controller gjy808 Electronic Projects Design/Ideas/Reviews 2 28th July 2004 11:08 AM
Light Controller or rather Electrical Outlet Controller mammanoti Electronic Projects Design/Ideas/Reviews 1 11th January 2003 04:09 AM
