| | #16 |
Well a slow diode will also do fine.Anyway a slow diode dosent mean it thurn on slow all diodes have very fast thurn on times the slow discribes its thun off time the diode stays conductive for some time after there is no curent.If you have like 100khz switching freq, a fast diode i needed. I used normal diodes on my coilgun but a single one could only take a few shots after shorting it self and since kiloamps are avaliable blowing the diode a part.3 parallel diodes work like a treat.I also had no reverse charge in the caps.
| | #17 |
Ok, I tried it out today. It worked suprisingly well, providing full control over the motor with fast switching times throughout and no voltage spikes from the induction (just 2 antiparallel diodes for clamping). The motor is at least 20A at 12v, it runs from a a lead acid battery and used to power a lawnmower (yes, a battery powered lawnmower!). The high current becomes clearer when after just a few seconds of use, the thinner white wires I used for some of the connections are rather warm (they arn't exactly thin, but the supplied wires are very thick in comparison). I have a video of it in use, contact me if you want to see it, nowhere seems to do a good free video hosting. I also realise moreso now why most motor controls switch at over 20Khz
__________________ Angry!? I'm absolutely electrolytic! Music web page: http://www.music-playground.net/artist/drem/ | |
| | #18 | |
__________________ I do not answer private messages asking for help because no one else can: benefit from advice I may give or correct me if I'm wrong. Please ask on the open forum if you have a question and I'll be happy to help, if I know the answer. | ||
| | #19 |
This huge motor is probobly very loud by it self. Video hosting? Try putfile.com (25MB)or youtube.com (100MB).
| | #20 | |
| | #21 |
Thats what basicly makes DC motors lose tork at high speeds.The inductance of there coil. I dont see how higher frq. are more eficent anyway. I know that 500Hz is more eficent then 50Hz in AC motors.
| | #22 |
Yeah, I made the mistake of touching a clamping diode after a few seconds of use and it was burning hot. That was a 6A one, so it really needs a bigger one (the practical solution would be a 10A TO220 diode I think, heatsinked). I tried both the 120Hz and 3Khz frequencies on it and found the 3Khz to be more effective. For one thing, the 120Hz really was too loud, and it had the typical stalling on lower RPM. 3Khz gave perfectly good control, but like I say the whistling noise is irratating. After a while, you can hear the motor noise over it, and of course on full, it dissapears altogether. My attempt at hosting the video: http://media.putfile.com/Motor-PWM-control
| | #23 |
Ouch this motor give ot a lot of sound when PWM controled! If it has high enugh resistace try conecting this to a audio amp it would act as a speaker quite good.Hehe
| | #24 |
Hi Dr. EM, I made a motor speed control very similar to yours for an electric powered model airplane. I also used a switching frequency of about 3kHz and it whistles loudly when 1st turned on then the air noise from the propeller drowns it out. I didn't use a diode across the motor, maybe I should for better efficiency. Instead I rely on the zener diode in the Mosfet to protect it by "wasting" the voltage spike when the controller switches off the current.
| | #25 | |
audioguru, you're also falling into the all to common trap of believing the protection myth believed by many nubes, the diode isn't used for protection but for efficiency's sake. Quote:
http://www.4qdtec.com/pwm-01.html
__________________ I do not answer private messages asking for help because no one else can: benefit from advice I may give or correct me if I'm wrong. Please ask on the open forum if you have a question and I'll be happy to help, if I know the answer. Last edited by Hero999; 1st July 2006 at 12:02 PM. | ||
| | #26 | |
| | #27 |
Interesting, possibly the diode wasn't switching fast enough.
| | #28 |
Then the diode would overheat.The inductance of the motor is restricing the curent flow a lot at such a high freq.
| | #29 |
I tried this circuit at over 20Khz in prototyping and found it worked very poorly operating a small computer fan.
| | #30 |
Hi all. The terms like "efficiency" and "protection" applied to the diode across the motor in a PWM circuit are both correct and both misleading. Its like saying that the wheels in a car are there for efficiency (rolling) and protection (suspension?), yes but the wheel is there to make the car run. Same thing with the diode - it is there to make the circuit run by letting the current circulate (free wheel is the term) through the motor -without the diode the circuit would be a BAD circuit. BTW the diode can be replaced by a transistor to improve efficiency (lower drop) when it is suitably switched.
| RGB Controller | erosennin | Electronic Projects Design/Ideas/Reviews | 4 | 10th March 2008 07:53 AM |
| using a PC as a controller? | omnyx | Electronic Projects Design/Ideas/Reviews | 3 | 13th July 2007 12:03 AM |
| Need Help on DC controller | 2K3vq | General Electronics Chat | 2 | 22nd April 2006 03:51 AM |
| sms controller | gjy808 | Electronic Projects Design/Ideas/Reviews | 2 | 28th July 2004 11:08 AM |
| Light Controller or rather Electrical Outlet Controller | mammanoti | Electronic Projects Design/Ideas/Reviews | 1 | 11th January 2003 04:09 AM |
