Old 19th June 2009, 12:20 PM   #91
Default Battery backup
Thanks to the help from members of this forum my battery backup is now working.
I have added details into the Master Clock word doc now at version 4
You can download it from here for the next 30 days. If you find this link after the 30days have expired let me know and I'll reactivate it.
https://vstuff.virginmedia.com/n/50-...4a2c3cc6a8a20/
Brett.
oliverb is offline
Old 19th June 2009, 09:23 PM   #92
SkyDrive - Windows Live
Microsoft's new online storage - 25 Gbyte
no timed restrictions, and nice HTML code to embedd the downloads.
nike6 is offline
Old 19th June 2009, 09:39 PM   #93
Thanks for that nike6 didn't know it was there.
Download the Master Clock file here.
Electronic Master Clock03v4.doc - Windows Live
oliverb is offline
Old 12th July 2009, 08:18 AM   #94
My Master Clock site has now moved to
http://www.brettoliver.org.uk/masterclock.htm
Full documentation is available for download in MS word format 28meg
or PDF 10meg
Electronic Master Clock03v4.pdf - Windows Live
oliverb is offline
Old 14th July 2009, 08:21 PM   #95
Originally Posted by oliverb View Post
Master Clock with DIY Slave Clock made using 30 sec movement from an old office clock. you can connect as many of these slave as you wish using extra relays or transistors as required.
All slaves can be advanced or retarded from the master clock.
Also 2 large 12" dial clocks with 30 sec and 1 sec syncronized movements. 1 sec quartz clock driver diagram also included.
The clock now chimes via a 4" longcase clock bell and 30sec clock movement(see pic).
Hi Brett
I noticed from you updated web site that you used a small relay with a bell hammer attached for the bell strike.what sort of relay did you use and did it prove worth while?
Mark
wombweller is offline
Old 14th July 2009, 10:29 PM   #96
Hi Mark it is not really a relay. It's a 30sec clock motor with the gears stripped out.
Brett.
oliverb is offline
Old 14th July 2009, 10:45 PM   #97
Brett.
Hi Brett
Realise that you made a bell ringer form a slave clock movement but also along side that from your website is another option using a relay or am I confused
Digital Master Clock with 7 Seg LED Displays & Hourly Ch
I'm just making one of my own but I ended up using a converted post office type relay (3000) Just thought yours with a miniature relay would be more compact!!!
Mark
Old 14th July 2009, 10:55 PM   #98
Originally Posted by wombweller View Post
Hi Brett
Mark
Just wondered what type of relay it was and if it performs ok!!!
Mark
Old 15th July 2009, 07:28 AM   #99
Hi Mark
The relay is just a small 5v relay (can't remember which one) that had a large armature so I could attach the wire to strike the old telephone bell.
This option is very compact and sounds nice but is not very loud. In the end I went for the large 4" bell and slave movement that can be heared all round the house. If you have more than 5volts to play with then you will have more of a choice of relays.
Your PO type relay sounds a good option though.
Brett.
oliverb is offline
Old 21st July 2009, 11:35 AM   #100
Good Job I like The idea
knaaphix is offline
Old 24th July 2009, 10:06 AM   #101
Default Specialized IC for digital clock
i want to make a clock using small amount of component. i find DS1307 but as fer as i know, it requires a micro-controller for which i have to program. unfortunately, i have no such facilities to program.
so i want a IC which is specialize for real clock and also avaliable in indian merkets.
plz help me.
regards.
sanjoy
sanjoy is offline
Old 10th August 2009, 08:27 PM   #102
Default Updated Word & PDF files
Electronic Master Clock03v6.doc - Windows Live
Electronic Master Clock03v6.pdf - Windows Live
oliverb is offline
Old 11th August 2009, 01:09 AM   #103
Default Awesome Project!
Thanks heaps for sharing this project, and putting such good documentation up for it.
I don't care at all that some might consider it too hard, or complex, that what's makes it so appealing in my book, I think this is an ideal application for a "Steampunk" design clock!
Has certainly got me thinking, and I really like the binary clock.
Kudos to you Oliverb!
aarggh is offline
clock, digital, displays, hourly, led, master, seg
