| Notices |
| Electronic Projects A collection of small electronic circuits and projects you can build. |
| View Poll Results: Did the transmitter work for you? | |||
| Yes, it is completely stable | | 13 | 54.17% |
| No it did not | | 6 | 25.00% |
| There is nothing special about it | | 5 | 20.83% |
| Voters: 24. You may not vote on this poll | |||
| Experienced Member | If you want to set the transmitter frequency as desired or free one you must have a possibility to change it. That can be done by trimming one of the elements in LC tank circuit. Situation can be fixed inductor (like a resistor or etched on PCB) and variable capacitor (trimmer) or a fixed capacitor and variable inductor. |
| Experienced Member | Can the audio Input be a square wave from a 555 timer? What type of capacitors did you use? It looks like Audioguru used Ceramics (NPO?) |
| | (permalink) | ||
| Experienced Member | Quote:
Of course, this thread also gave me another idea, Essentially, It could be used with any Mp3 Player and be able to transmit without the need for wifi. That means I could build a stand alone computer, Put all my Mp3's on it, and Have it play continuously. Then I would also be able to receive it anywhere within the house, Or even Outside. Is this transmitter AM or FM? How did you make you Inductor out of PCB? Did you use Eagle to draw the PCB or some other program? | |
| | (permalink) | ||
Instead of making a mono FM transmitter toy that drifts its RF frequency, why not make a Stereo Micromitter that uses a modern IC with a crystal controlled frequency synthesizer and a phase-locked-loop for stability. http://electronics-diy.com/schematic...ransmitter.htm
There was a transmitter I found that was made by micrel, MICRF103 (transmit) and MICRF005 (reciever), but they can only be used with digital, and run from 800Mhz to 1Ghz | |
