Old 22nd May 2006, 06:01 PM   #46
Originally Posted by Someone Electro
You have all the information you need.
If you know so litle you better stay awey becuse a coilgu means dealing whit high volategs at high curents.
i just want a layout diagram for the coil part. i know the rest.
thanks anywys
mikhail666 is offline
Old 22nd May 2006, 08:03 PM   #47
Ummmmm
What?
I dont realy understand what you want
Il give you shocking experience.
Someone Electro is offline
Old 24th May 2006, 02:56 AM   #48
Thumbs up
that thing is sweet maybe ill make one myself
brihoo2k is offline
Old 24th May 2006, 12:31 PM   #49
Feal free to.
Get some caps of ebay.Get a big SCR or parallel lots.
Old 25th May 2006, 02:28 PM   #50
the foil in place of the coil is a nice effect too...try some steel wool as well
be sure to do all those ouside though...huge fires will start in the house lol
anyways heres a link to a site that has allot of high voltage projects along with coil guns
http://4hv.org/news.php
i believe you have to sign up to get to the boards there
Dave
www.myspace.com/sonicorbstudios
Welcome to "Sonic Orb Studios"
moody07747 is offline
Old 25th May 2006, 05:15 PM   #51
Yep its prety spectacular. Even whith 90Joules i got big sparks flying.
I got a 880 Joule bank and the resulty should be prety big and loud.
Old 25th May 2006, 05:50 PM   #52
Perhaps I better get a map out?, and see how far you are from the centre of the UK
I live pretty well dead centre of the UK, as far from the sea as you can get, in fact a village a couple of miles from me is one of a number who claim to actually BE the centre of the UK. Apparently it depends how you measure it!.
Old 26th May 2006, 05:32 AM   #53
Dont wory you live far enugh LOL
Old 31st August 2006, 05:13 AM   #54
try this one much more powerful coil gun
muki55 is offline
Old 31st August 2006, 06:33 AM   #55
I am not sure that it is anymore powerful. The only advantage of that design is that it uses multiple stages, which can increase efficiency.
4700uF at 25V contains much less energy than 10000uF at 100V. If you want you can use the formula Energy(Joules) = (CV^2)/2. Also, multistage designs require a lot more tweaking.
freeskier89 is offline
Old 31st August 2006, 10:08 AM   #56
Fist of all as menthones the powersuply is way to small
2nd using a BJT transistor in a coilgun is stupid,becuse they can only handle about half times more pulse curent than continues.(somthing like 15A wont get a projetile very fast)
3rd it has no protection diodes.The transistors and the counter IC would get fryed by the negative pulse.
Also this is a open loop design,wich means it only times the thurn on times.A proper multistage guy has optointerupters to detect the projetiles postition and fire it at the ptimum time no mather the projetile size and weight.Closed loop designs need a lot of tweking just to get the projetile out of the barel and a lot more tweaking to get it to a good speed.
EDIT:
Noticed a nother thing.There is a 16V cap on a 25V suply line.Cap would pop.
Old 7th September 2006, 03:41 AM   #57
Small Coil Gun SCR trigger. huh!!!!!
muki55 is offline
Old 7th September 2006, 04:46 AM   #58
Thats a prety complicated sicruit just to drive a SCR.
All i did was a voltage source and a resistor to gate.
Old 7th September 2006, 05:30 AM   #59
I am not totally sure what you are trying to say, but yeah, I would recommend that design over the other one you posted, but I agree with Someone Electro, that the SCR drivin g part of the circuit could be a LOT simpler and it would work exactly the same. Its kind of like putting in a voltage regulator when you are just trying to saturate a BJT; you could use a vreg, but a resistor would do the same thing and save many components
Old 8th May 2007, 02:07 AM   #60
anyone still following this post ?
venomxx is offline
coil, gun, simple
