| Notices |
| Electronic Projects A collection of small electronic circuits and projects you can build. |
| Experienced Member | Just conect the LED to the jack whitha restor and you have your tramnsiter
__________________ Il give you shocking experience. |
| New Member | i think the qwestion was post a circuit... i would like one too... even a note on a napkin will do (i hope i dont regret that...) thanx in advanced |
| Experienced Member | Do you know how to conect a LED to a batery? This is the same exsept the batery is a click in jack
| Experienced Member | what is a restor? I couldn't find its definition from hyperdictionary.com.. Something to ask about the 3.5mm jack. As i know, there are 3 terminals at the jack, can i know which one represent what?
__________________ Superman Returns.. http://www.supermanhomepage.com/imag...an-returns.gif My friend created this account for me.. LOL http://bananasiong.myminicity.com oh.. somemore http://bananasiong.myminicity.com/env |
| Experienced Member | Analog audio has a stadard of 2V +/- output.So you need a resistor that will let trough about 20mA whith a aproximete half volt drop. Ohoms law says 25Ohm a comon resistor is 22Ohm so use that. Google wil find you audio jack pinouts.And wikipedia wil give you lots of info about resistors and IR LEDs.
| New Member | do you have a circuit for the sound to IR converter? and the Phototransistor circuit needed to input the IR signals to the PC. Thank You |
| New Member | begging for a schematic of the said project. Thank You. |
| Experienced Member | Plz I'm so pathetic I can't think for myself. |
| New Member | tried makin the transmitter, with that LED and the 220ohm resister, used a common audio jack. the thing is how do i make that phototransistor circuit for the input of the signal> ? |
| New Member | Anyone, please post a circuit daigram of the IR transmitter and recorder. Thank You |
| Experienced Member | I've tried 2 IR's with a 220R resistor - can't seem to get it to work. Also can't seem to find the IR device on the griffin site - do they still make it? |
| New Member | got the receiver running and recording. the problem now's the transmitter. seem's that it can't get enough juice from the audio output of the headphones socket. using a digicam, can't see any light(digicams can see IR) |
| Experienced Member | A headphones output is not powerful enough to light an LED. You need to light the LED with its resistor with a DC power supply or battery then modulate the DC with the audio from the headphones jack capacitor-coupled to it.
__________________ Uncle $crooge |
| New Member | i see, i see. that's what i've been tryin to do. haven't got it right yet though. a little help on a diagram. thanks |
| Experienced Member | To calculate the correct value of a current-limiting resistor for the IR LED, we need to know its forward voltage at 20mA and its max continuous current ratings. We also need to know the supply voltage of the transmitter and which type of battery it uses.
