Old 30th August 2006, 07:48 PM   #16
Hi Hero,
You are correct. The transformer will be overloaded if it has the same current rating as the project's output current.
The power passing (VA) rating of a transformer should be used to specify it. Then the power wasted by heating the recifiers and regulator will be included.
audioguru is offline
Old 30th August 2006, 11:03 PM   #17
What make the situation even worse is that the power isn't drawn thoughout the AC cycle but in surges at the high parts of the waveform. These surges overload the transformer in extreem cases causing core saturation which increases losses (and therefore heating) even further.
if I know the answer.
Hero999 is offline
Old 31st August 2006, 01:58 AM   #18
I don't think a transformer manufacturer would make a transformer so poor that its core saturates when it has a rectifier and filter capacitor feeding a load and it is operating within its ratings.
Old 31st August 2006, 10:20 AM   #19
There are still those ultra cheap tranformers that barly work under low power conditions
Il give you shocking experience.
Someone Electro is offline
Old 31st August 2006, 10:29 AM   #20
I've seen many transformers feeling so hot to the touch by just idling without any load connected. This is a sign of inferior core material or some core saturation occurring. Could be all cost related.
L.Chung
eblc1388 is offline
Old 31st August 2006, 04:13 PM   #21
Several years ago I bought a Triad isolation transformer. It gets too hot to touch, even with no load. I emailed Triad, saying that I thought it had a shorted turn or something. They wrote back saying that that's the way it's designed. Didn't give me a lot of confidence in Triad.
Ron
Roff is offline
Old 31st August 2006, 04:14 PM   #22
A cheap transformer gets hot without a load because its primary doesn't have enough turns to make enough inductance. The cheap primary is just a long piece of wire. Sure it gets hot.
Old 31st August 2006, 04:15 PM   #23
Don't you mean gave you none at all?, and never used them again!.
Nigel Goodwin is online now
Old 31st August 2006, 04:20 PM   #24
I guess I'm master of the understatement.
Ron
Roff is offline
Old 31st August 2006, 04:27 PM   #25
Yeah, I thought about that. More inductance means more turns of heavier gauge wire, and that leads to a larger core, both of which raise the cost. Well, I seem to recall selecting it because it was cheap (in the true sense of the word, as it turns out). You get what you pay for.
When I get home, I'll check to see if it's rated for 220V also. If it is, that sucker should be glowing red on 220.
Ron
Roff is offline
Old 31st August 2006, 08:49 PM   #26
I don't either, but if you connect a 1A load to a capacitor and rectifier connected to a 1A transfomer it will draw huge 3A pulses with an RMS value of 1.414, which will overload it.
I've teasted my theory using a scope, a LM317 constant current source, a transformer, capacitor and a small 0.5ohm current sensing resistor (two 1ohms in paralell.
Hero999 is offline
Old 1st September 2006, 08:59 AM   #27
The relevent word there is 'PULSES', it's NOT 3A continuous, and the transformer is (or any decent one will be?) designed for it.
Old 1st September 2006, 01:46 PM   #28
I think a rectifier charges the main filter cap with current pulses that are about 10 times the load's current. All power supply parts are designed for it: the transformer, rectifier bridge and main filter cap.
Old 1st September 2006, 02:28 PM   #29
The magnitude of the pulses will depend on the filter capacitor. Somehow I find if difficult to believe that a 10A pulse won't cause the core to saturate, there again the pulses are quite short so I don't know.
Hero999 is offline
Old 1st September 2006, 02:53 PM   #30
I have never measured a cheap transformer that has a cheap soft iron core instead of carbon steel, maybe has a core that isn't even laminated with insulated laminations, and without enough turns on its windings to be efficient. Some guys have and insist that the peak voltage is the same as the RMS voltage due to the transformer compressing the voltage peaks.
I wouldn't say the cheap transformer saturates its core, I would say that its peak current operates it on the curve of its magnetic hysteresis graph, so it is approaching core saturation.
Current limiting Help PLZ Frosty_47 General Electronics Chat 32 24th July 2007 04:51 PM
Current limiting madmikejt12 General Electronics Chat 21 19th June 2007 08:19 PM
Low current power supply from stored current. McGuinn Electronic Projects Design/Ideas/Reviews 12 20th January 2004 07:15 AM
Current rating of power supply shiv General Electronics Chat 3 28th May 2003 06:03 PM
Power supply/ current supply design inkedallusion Electronic Projects Design/Ideas/Reviews 1 17th December 2002 02:10 AM
