| | #16 | |
Current in induced in the secondary winding when the mag flux changes. The mag flux increases when the primary transistor is on and creates current in the secondary. When the transistor is off, it decreases and makes current in the other direction. The sum of current over time must always be zero. The shape of the waveform is typically undesirable- when the transistor is on, flux increases rapidly making a high current spike on the output. Then it decreases at a more moderate rate when the transistor is off. However, the core flux is always in the same direction. It increases and decreases but does not reverse, so the core is essentially biased at all times like an electromagnet. This reduces the capacity of the core. Furthermore, if you do not allow enough time for the flux to be drained by the load during the "off" period, current will increase even higher the next "on" period and so on until the core flux reaches a saturation point. At that time the current during the "on" period is limited only by the total resistance in the primary circuit and will typically draw enough current to smoke. It is not a very appropriate design. He needs a split primary pretty badly.
__________________ I thought what I'd do was I'd pretend I was one of those deaf-mutes. | ||
| | #17 | |||||||||
Try connecting the primary of a small mains transformer to an AA battey in series with a switch, connect a neon lamp to the secondary. When you hold the button the neon might flash very dimly as the field builds but it will flash even brighter when you release the button as the field collapses and notice the corrona is only generated around one electrode. Quote:
But it does use pulsed DC, read the link I posted before. I've bought cheep DC fluorescent tube fittings before and one end of the tube always goes black and it doesn't illuminate uniformly
__________________ I do not answer private messages asking for help because no one else can: benefit from advice I may give or correct me if I'm wrong. Please ask on the open forum if you have a question and I'll be happy to help, if I know the answer. Last edited by Hero999; 16th August 2006 at 12:11 AM. | ||||||||||
| | #18 | |
The reason one end blackens is because the AC used isn't symmetrical, nothing to do with 'pulsed DC'. It's simply because the inverters used are crude, and waveshape isn't of much concern. | ||
| | #19 |
Running a tube with too little current will also blacken the ends in short order. I assume doing it with too much current will do the same thing. Waveforms which heavily deviate from a sine wave are a problem, but so is failure to regulate tube current. IIRC those great compact flourescents actually require a bit of starting cycle algorithm to get long life. Take one apart sometime, the 110v ones- even the cheap ones- still have like two dozen components inside. There are some quality 12V DC devices out there: http://www.oksolar.com/n_cart/search...xtures%2012VDC And these are some excellent 12v DC lamp bulbs. They're really good. I've used them. http://www.oksolar.com/n_cart/search...=Light%20Bulbs They're certainly expensive for a flourescent, but those are not the "crude" solutions mentioned. The simple answer is to simply use a power inverter.
| | #20 | ||
How about this:? This inverter is no good because the AC waveform it produces is very asymmetrical (mostly negitive). Current only flows in one direction through the tube the electrons are only emitted from one end of the tube, this causes one end to be brighter than the other and excess electrode splutter also occurs at one end cause it to go black.
__________________ I do not answer private messages asking for help because no one else can: benefit from advice I may give or correct me if I'm wrong. Please ask on the open forum if you have a question and I'll be happy to help, if I know the answer. | |||
| | #21 | |
![]() I have begun to profile different threads. The first thing I do when I see a thread with more than 600 views is check the dates. If you see a thread with like 6 replies and 1500 views it seems to almost always be revived. EDIT: In this case 19 replies and 2023 views LMAO | ||
| | #22 |
Anywaym powering a fluorescent tub is a very common request, and it' easy to do but harder to do properly. If you have any more questions then I can point you in the right direction. Really the only hard part is the transformer which can be a bit experimental but it's not too bad really.
| | #23 |
Its more efficent to go and buy a CCL for computer modding. You can get em cheap for 2 bucks at SVC when they have deals. All things for computers work for 12V, all you would have to do it modify the connector. http://svcompucycle.stores.yahoo.net/12vb2ccflwht.html White, they go for 6 bucks. | |
| | #24 |
They won't power standard fluorescent tubes though but I see what you mean, the idea is to use the CCL instead.
| | #25 | |
| | #26 | |
| | #27 |
That's exactly what I was talking about. http://www.repairfaq.org/sam/samschem.htm#schmp1
| | #28 |
Built this one but I can't get it to work somebody please help.
| | #29 |
Have you tried swapping the base connections to the transistors?
| | #30 |
Hi hsab...nice tricky oscillator but is this circuit is reliable?
| 12v, fluoro, inverter, lamp, power, project |
