| Notices |
| Electronic Projects A collection of small electronic circuits and projects you can build. |
| New Member | if you need to check the transformer is ok,check it by applying ac to the primary,set your meter to read ac volts and connect it to the transformer secondary-if there are any faults with the windings they will show up when checking in this way(without a load on the tx the secondary volts will be a little higher than usual,but not by a great deal) if you want,you could always ring the tx primary and check the secondary waveform with your scope.....but why make things too complicated when a simple continuity test or voltage test will suffice? regards mike |
| Super Moderator | Quote:
You seem to be limiting the testing to mains transformers?, but the ringing test can be used on many more, audio transformers, switch-mode transformers, non-mains power transformers, line output transformers etc. It's a far more useful test than a simple ohms test, and faster and safer than a mains test. | |
| New Member | |
| New Member | :lol: you will have to forgive me as far as ringing transformers goes-be they audio,smps or flyback(and deflection coils )i am very much old school and set in my ways in that respect. hand held testers are handy to use ,ive built one specifically for testing flyback transformers and scan coils-it also will check audio txs etc-but being able to view the resultant signal on the scope is sometimes very much a necessity. regards mike |
| New Member | Yes i like it but. What is the neon bulb? A neon bulb mean LED or any thing else
__________________ Cool Jasim |
| Experienced Member | maybe this is a dumb question but how often do transformers fail with a short inside the coils? I guess if they really got cooked and melted the insulation on the wires it could happen but wouldn't that be pretty obvious from a visual inspection? |
| New Member | Quote:
But u say that neon bulb require 70V to 90V to stike. And in transformer checker circuit 6V battery is used. What u saying about this?
__________________ Cool Jasim | |
| New Member | |
| Experienced Member | The transformer will easily create a high voltage pulse and light the LED/neon bulb when you release the switch. I had a transformer with a 1mH coil that I was switching with a MOSFET (ignition coil primary) that was being charged with 12V. The voltage spike at the drain of the low-side-switch n-channel mosfet was >200V. Last edited by speakerguy79; 11th June 2008 at 09:13 PM. |
